Day in a life of a 996TT motor build
Rating: Thread Rating: 7 votes, 5.00 average.
Old Oct 6, 2004 | 12:55 PM
  #31
PorschePhd's Avatar
Ok, time for more pics…
We talked about the pressing in and out of the liners. Below is a picture of the procedure for pressing it out. I use a hydraulic press to do this. Notice part of the Porsche tool in the liner.
The next picture show the liners on the outer cylinders and the factory spacer tool behind the cylinder block.
This is a picture of one of the two circlip tools you will need. There is an art to using these and making them help rather than hurt. Install it wrong and the circlip will pop off and roll into the newly sealed case. You guess it, hope you are good at fishing.
Next is the picture of the piston being compressed in the ring and supported by the Porsche OEM tool.
There are other ways to do this procedure, but to be honest the OEM tool keeps it simple. You will not loose time by continuously slipping past the rings.
One of the interesting things about the 996TT pistons that is unlike any Porsche piston from the past is the second ring land. The groove has a dowel as seen in the picture that prevents the ring from spinning in the cylinder. When reringing the piston I highly recommend you place the oil scraper ring away from the bottom of the cylinder. This will prevent unnecessary smoking from time to time.
Once the cylinder assembly is installed on the spacers you will need one of these. Once again this is about an 800.00 tool.
Here is the tool installed and live at work.
This picture shows the headgasket. When installing notice the orientation. There is a face of the gasket. The gasket is a three part gasket riveted together. There is only one way to install this.
Here are the heads back on the motor and torques to spec.
One nice upgrade is the use of the older style chain housing gaskets. The 993 style has about a .5mm more rubber on it than its newer brother for the 996TT. The gasket on the left is the 993 version, the gasket on the right is the 996TT gasket. They are interchangeable. I also suggest this to the chain tensioner gaskets.
Old Oct 6, 2004 | 01:00 PM
  #32
keoni1978's Avatar
keoni1978 is infamous around these parts
Awesome write up!! How often do we get to see the heart of a Porsche Turbo
Old Oct 6, 2004 | 06:08 PM
  #33
MrBlonde's Avatar
Awaiting Email Confirmation
MrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to all
Fantastic thread, much appreciated.
Old Oct 6, 2004 | 09:05 PM
  #34
PorschePhd's Avatar
Opps I forgot a picture.
Old Oct 6, 2004 | 09:12 PM
  #35
Rave TT's Avatar
Happy Now?
Rave TT is a jewel in the roughRave TT is a jewel in the roughRave TT is a jewel in the rough
Best thread ever!!! Thanks for sharing.
Old Oct 6, 2004 | 11:18 PM
  #36
TCM's Avatar
TCM
TCM is infamous around these parts
This is definately the best thread ever on 6speed IMHO. Time to make it a sticky.
Old Oct 6, 2004 | 11:44 PM
  #37
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
Awesome writeup and photos! Yes I agree that this is the best thread ever made in 6speed.
You have convinced everyone of us about your skill and knowledge about Porsche. You da man and next time I afford a new Porsche, I will pass it to you!
Old Oct 6, 2004 | 11:55 PM
  #38
DJ's Avatar
DJ
WOW - Stephen on of the best posts ever on 6speed!
Old Oct 7, 2004 | 04:15 AM
  #39
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Great DIY project!!!!
Thanks for sharing Stephen. That is true Porsche ****!!!
Old Oct 7, 2004 | 08:45 AM
  #40
mike@evo's Avatar
mike@evo is infamous around these parts
Kasper, nice shoes!!! I am following you step by step with our motor! Thanks, Mike
Old Oct 7, 2004 | 08:46 AM
  #41
sharkster's Avatar
Mike.. just make sure you add some gin and tonic to EVERYTHING and you WILL get more HP
Old Oct 7, 2004 | 09:42 AM
  #42
PorschePhd's Avatar
LOL, those are the Skechers baby!!
Old Oct 7, 2004 | 12:05 PM
  #43
sharkster's Avatar
Do cams Stephen! Or are you all back together again?
Old Oct 7, 2004 | 03:24 PM
  #44
ebaker's Avatar
ebaker is infamous around these parts
Those Carillo's are beautiful. Was the crank end play out of spec? I wonder if the heavy clutch and power clutch assist might be causing the thrust bearing wear?
Old Oct 8, 2004 | 01:58 AM
  #45
PorschePhd's Avatar
No it wasn't it was right on. I will say though with the motor together and trying to srag the valve train and just turning the motor over is tough.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
