Coil pack location?
Old Mar 30, 2009 | 05:35 PM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
Coil pack location?
Guys,
Been doing some hw on coil packs as they seem to be one of the "maintainance" items to keep in mind.
Can anyone post where they are (or pics if available) so I can take a look at the boots?
Starting to make sure all is in order for Spring time!
Thanks!
Old Mar 30, 2009 | 06:41 PM
raineycd's Avatar
Those are deep on the 996TT. Pretty much follow the spark plug change DIY and they are the last thing you take off to get to the plugs.
So to get to them, you will have to take off the rear bumper cover, tail lights, rear fender liner, intercoolers, and some heat sheilds. Then, you can see them...
I would wait until you are due for plugs, then inspect them as you have them off.
Old Mar 31, 2009 | 08:03 AM
s14roller's Avatar
Hmm, there's no way to get to them before removing all those items? I believe my plugs only have like 1-2K on them...
I just figure it may be a good idea to inspect them, and make sure they are "clicked" all the way in.
Old Mar 31, 2009 | 09:08 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
"you can't get there from here"...... Rain is right. Sorry bro.
Old Mar 31, 2009 | 09:24 AM
raineycd's Avatar
You shouldnt need to check them unless you are having ignition issues such as a misfire or something. If you are hitting on all cylinders, then you are ok - just check them next plug change...
Old Mar 31, 2009 | 09:53 AM
s14roller's Avatar
K, good to know guys. Car has about 30K on her so miles wise, not high, but rubber tends to crack with age. I'll look into it but so far, she runs great.
Old Mar 31, 2009 | 10:07 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
You will know when one goes bad. Sometimes the problem become worse when it is wet out.
Old Mar 31, 2009 | 10:54 AM
raineycd's Avatar
My car has a little less than 40k and I just did plugs and the coil packs looked great.
twnj
Apr 29, 2016 05:18 AM
BauerR
Sep 4, 2015 10:47 AM
ECS Tuning - VW
Aug 26, 2015 02:54 PM
