Engine question????
Old Oct 8, 2004 | 12:03 PM
RacerX's Avatar
RacerX is infamous around these parts
Engine question????
does anyone know what differences, specifically, would be found in comparing a stock 01 turbo 996 engine to a stock 04 turbo 996 engine??
thanks
Old Oct 8, 2004 | 12:12 PM
cjv's Avatar
cjv
Moderator
The case.
Old Oct 8, 2004 | 12:19 PM
RacerX's Avatar
chad..
could u be more specific....when u say the case is the ONLY change mechanically the outer case of the entire engine? bottom? lower? other than the case which my limited knowledge means to me the outer part that just surrounds the engine? if that is the only change what has changed about the case and how does that make the engine "better" if at all?
Old Oct 8, 2004 | 12:23 PM
cjv's Avatar
cjv
Moderator
Re: chad..
The case is reinforced. It is stronger. It will take more power. If you look at the two cases side by side you will notice the "ribs" on the sides.
If you go to Rennlist, 996tt forum, the thread by Kevin entitled The Quest for Maximum HP, page 6, you will find pics of both cases.
Old Oct 8, 2004 | 09:31 PM
PorschePhd's Avatar
I disagree here. I know of three failures with the new case right now. Brand new cars that had to have new cases from leaking. The molds and castings are worse than the original. Lots of profiling, no finish work. They cut some real corners here. Stick with the older style. This type of crap is not common with the older case. The desgin has been around for too many years.
Old Oct 8, 2004 | 09:38 PM
cjv's Avatar
cjv
Moderator
Stephen,
Thanks, that is good information to have. I would expect anything that is new as in "out for the first time part" to have some bugs to work out. I am sure they have been working out these bugs.
My point is the case was changed and it is stronger. At what power range this would be an issue ....... I don't know. I don't know of any failures of the old case to about 900 hp as of yet.
Old Oct 8, 2004 | 09:47 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
So you feel the 964 case is superior to the new Spanish 996 case???
Old Oct 9, 2004 | 10:39 AM
Matt Fresh's Avatar
Matt Fresh is infamous around these parts
Re: Engine question????
thanks
I know that they changed the spark plugs in MY2004. The prev. generation plugs will foul out after a short time when you start modding the car, and will cause you to lose power.
Its funny when you pay this much for a car, it comes with ****ty plastic bypass valves that inevitably fail and spark plugs that foul.
Old Oct 9, 2004 | 11:13 AM
PorschePhd's Avatar
Hell, the casting on the old case has gone to heck. The runners on the spigots look the same. I thought I had crap in the case until I tried to wipe it. The casting in general I suspect is the same as on the Spain case. The older case will put up with abuse. Pin it and you will not have to worry. No one knows yet about the new stuff. We will have to wait for Kevin to get his running. Like anything, Porsche will correct the issues. It will take a few to get with the program. You can bet if we know, Porsche has known far longer than us.
Oh, and Spain, hell....My heads were made in France!
Old Oct 9, 2004 | 11:34 AM
cjv's Avatar
cjv
Moderator
Originally posted by Kevin
I have purchased a new Spanish case. The casting finish is poor. If you were to drag a cloth rag over the case it would get caught in all of the burrs. One could fix all the flaws with a die grinder and cleanup all of the flaws. It seems like every new casting that Porsche has, they do develop some teething issues. There is noticeable web stiffening, in the lower section of the case. And it is lighter... You folks can see it here.. http://forums.rennlist.com/rennforum...4&page=6&pp=15
Well Kevin, aren't you going to boat tail it.
Old Oct 9, 2004 | 11:37 AM
cjv's Avatar
cjv
Moderator
Re: Re: Engine question????
They changed the plugs on the turbo's way before 2004.
Old Oct 9, 2004 | 12:00 PM
PorschePhd's Avatar
02' they did the plugs.
Old Oct 9, 2004 | 12:23 PM
ebaker's Avatar
ebaker is infamous around these parts
The new spark plugs were introduced into production on Aug. 14, 2001. The heat range was increased from 5 to 6. (TSB 2870) I'm trying to get the dealer to replace mine under warranty. I don't think thet are going to though.
Old Oct 9, 2004 | 02:27 PM
sharkster's Avatar
Kevin I wish you were coming to the shoot out
Old Oct 9, 2004 | 02:44 PM
sharkster's Avatar
I'll be there! The car won't...
That's cool but it's still too bad your car won't be there I'd love to see it run and kick some booty...
