Increase in boost
Old Apr 14, 2009 | 09:29 PM
rwilliamtaylor's Avatar
rwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of lightrwilliamtaylor is a glorious beacon of light
Increase in boost
My X50 just started boosting at up to 1.3 bar... no S/W changes. It runs great until the boost hits 1.3 and then it backs off.
Any ideas?
Old Apr 14, 2009 | 09:44 PM
wross996TT's Avatar
Check wastegates to see if they are stuck. Get the codes read....be careful driving with this...
Old Apr 14, 2009 | 11:06 PM
Turbo Fanatic's Avatar
You are definitely hitting throttle shutdown. Get it checked before you need a new engine.
Old Apr 15, 2009 | 09:58 PM
Turned out the 2 inch rubber hose between the Y pipe and the boost control solenoid was broken. I just had the alternator changed and the Y pipe was removed a couple of times. Must have weakened the hose by taking it on and off.
Fortunately, a cheap fix this time...
Evan5469
Oct 29, 2015 06:39 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
rsdub
Sep 10, 2015 03:30 PM
Sep 3, 2015 04:56 PM
