anyone running a proto style air system with and EPL tune?
looking for some hp numbers or 60-130's ... someone with a protomotive style blow thru ford maf and and EPL tune . would like to see if there is a hp difference acording to the vbox im only putting 602 hp at 1.3bar to the wheels seems low
i am running
k24/20g
60lb deka injectors
3.8bar fpr
104 oct sunoco gt plus fuel
2.5 inch fender well proto air intake
ford blow thru maf
4.5 inch ic's
thanks
tim
i am running
k24/20g
60lb deka injectors
3.8bar fpr
ford blow thru maf
4.5 inch ic's
thanks
tim
I think he's just trying to figure out why he's not seeing more power out of his set-up.
Tim, it does seem a little low. What's Todd K think of the numbers. With your setup, you should be putting down over 700, no?
awd off a vbox...
i talked with todd last week i was supposed to get down there this week for a dyno tune (another 2k ouch) but he had some personal stuff come up.. he was thinking that he could get 700 to the wheels on 104oct... ill attach a data log file of the pulls
your 602 whp is right on with a brake hp of 750. Is the 750 kit supposed to provide 750 brake at 104 octane? if so, then I would say you are right on. Sorry for the ignorance on my part, but not sure how these kits are numbered.
Tim,
I believe Tony can tune with a blow thru MAF. He was going to tune my car when I had the Ford MAF and Proto pipes installed (blow thru), but we tried a Bosch program for comparison and I preferred the drivability of the Bosch programming, so we went in that direction. I re-installed the OEM intake. Tony is familiar with blow-thru tuning and has done it on other cars (other than Porsche), so I think it may be an option for you.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Tim,
i am running
k24/20g
60lb deka injectors
3.8bar fpr
ford blow thru maf
4.5 inch ic's
thanks
tim
i am running
k24/20g
60lb deka injectors
3.8bar fpr
ford blow thru maf
4.5 inch ic's
thanks
tim
i am running
k24/20g
60lb deka injectors
3.8bar fpr
ford blow thru maf
4.5 inch ic's
thanks
tim
i am running
k24/20g
60lb deka injectors
3.8bar fpr
ford blow thru maf
4.5 inch ic's
thanks
tim
I have similar turbos to you, but have stock intercoolers, stock intake box and filter, 58lb injectors with a 5bar, and in RWD on a dynojet I made 621rwhp at 1.3 spike, settling to about 1.25ish bar. I don't have a box, so I don't have any 60-130 #'s to give out, but I might be taking the car to the strip before it moves on to the new owner to see what it traps.
Tim
I would be concerned on my engine with these numbers but since your engine is not on a stock bottom end they may well be fine.
