Engine cut off at 5000rpm - no CEL
Old May 10, 2009 | 03:18 PM
mcisprinter's Avatar
mcisprinter is just really nicemcisprinter is just really nicemcisprinter is just really nicemcisprinter is just really nicemcisprinter is just really nice
Hi
I was on the highway in 6th gear cruising along at 55mph and decided to overtake a car. I proceeded to downshift into 3rd gear and floor it. Around 5000rpm, I hit what felt like a rev-limiter. Any ideas? It's maybe the second time in about a month. Some facts;
-Never had a CEL
-23000 miles 2003x50
-exhaust (fabspeed) and intake (evo)
-no other engine modifications
-Been driving for 30 minutes on highway, engine was at right temp
-I only use 94 octane gas
PSM was on but didn't see any light flash ...
Rob
Old May 10, 2009 | 03:26 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Failing plugs usually are seen under load around 4-5K in the rpm range... Original plugs?
Old May 10, 2009 | 04:19 PM
Turbo Fanatic's Avatar
Plugs
Old May 10, 2009 | 04:43 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Yep. I am getting this same thing intermittently about the same RPM in higher gears.... will be getting plugs very soon. I am just trying to time it with other upgrades since it's the whole "as long as you're down in there....." deal
Old May 10, 2009 | 07:12 PM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
I had the same thing happen a few months ago. 1st time it happened I got CEL, ABS, and PSM light. The all went away after I restarted the car. Everytime after at 5,000 (around .5 boost) the cars a$$ end shock like hell and power was gone - and I never saw any more CEL-ABS or PSM lights. Turned out to be the plugs.
I will say the new plugs make all the difference in the world.
Old May 10, 2009 | 07:14 PM
Kinds feels like you hit a rev limiter right?
Old May 11, 2009 | 07:06 AM
Thanks guys, the consensus seems to be plugs so I'll get that taken care of ASAP.
Yes, it felt exactly like a rev limiter.
thanks
Old May 11, 2009 | 12:07 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Maybe a MAF issue but less possible due to low amount of mods. Plugs may be also the next one to look into. Disconnect MAF sensor on top and drive it. If it does not happen again then it was the MAF. If it still cuts at 5K rpm then plugs.
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
bmwtmx
Aug 26, 2015 07:26 AM
oddjob142
Aug 24, 2015 05:49 PM
