Radiator bleed Help!
Old May 12, 2009 | 05:17 PM
SIC996's Avatar
SIC996 is infamous around these parts
Replaced the center radiator and have looked and found I need the radkitplusa from snapon to bleed the system and wondering if anyone can help this moron (me) figure out how to hook it up etc..
Old May 12, 2009 | 05:22 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
You may not need it. How much coolant did you loose when you changed the rad. When I did my GT2 nose/rad conversion all I did was jack the car up at the back and let it bleed by itself.
You may still get a pressure lock and pop a hose but I think you might be OK. Jack the car up as high as possible at the back and then run the car. You will be OK unless you lost tons of coolant in the change.
Ben
Old May 12, 2009 | 05:49 PM
SIC996's Avatar
I lost most as I had a piece of metal from a car infront of me go through it! I tried to jack it up in the rear, but it kept puking it out the fill tank
Old May 12, 2009 | 05:52 PM
BigBadBen's Avatar
Ah then your *uggered Yup you need a large compressor to create the vaccum needed. I have done it many times using the snap-on tool.
Old May 12, 2009 | 06:00 PM
SIC996's Avatar
is it straight forward as far as hook up? I assume you attach it to the fill tank?
Old May 12, 2009 | 06:05 PM
BigBadBen's Avatar
Yes, you stick the rubber end into the expansion tank and tighten it down with the steel ring. Create the vaccum and one clear plastic hose goes in the large bucket of your new coolant mix and the other clear hose goes into another bucket for over flow... you will figure it out. Create a 20-25 PSI vaccum and your done. Use the Audi coolant, it's cheaper than the P-car stuff and the same spec.
Old May 12, 2009 | 06:07 PM
SIC996's Avatar
thank you I appreciate it.
Old May 12, 2009 | 06:09 PM
Mack Pence's Avatar
Mack Pence is a jewel in the roughMack Pence is a jewel in the roughMack Pence is a jewel in the rough
did you attach it to the fill tank???
Old May 12, 2009 | 06:12 PM
SIC996's Avatar
Thats my understanding
Old May 12, 2009 | 06:15 PM
BigBadBen's Avatar
Yes, the main reservoir. It was my pleasure to help.
Glasgo
Nov 30, 2015 02:37 PM
White991TT
Oct 25, 2015 12:29 PM
no1joey
Oct 4, 2015 11:23 AM
bongnation
Sep 25, 2015 02:58 PM
markj
Sep 20, 2015 04:19 PM
