Boost leak
Old May 14, 2009 | 02:10 PM
VEGAS BAIL's Avatar
VEGAS BAIL is just really niceVEGAS BAIL is just really niceVEGAS BAIL is just really niceVEGAS BAIL is just really niceVEGAS BAIL is just really nice
Question Boost leak
ok so i sent my ecu back to evoms to get the upgrade and my car is still not getting all the boost it should, so my question is, Is it hard to check to see if there is a boost leak and how time consuming is it.
Old May 14, 2009 | 02:18 PM
Betim@BBIAutosport's Avatar
Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !
start to finish, it shouldn't take no more than 35mins.
I use this:
http://cgi.ebay.com/ebaymotors/FMIC-...motiveQ5fTools
..you need that plus the correct silicone reducer.
Remove intake. connect the silicone reducer the the plastic piece from ebay link. Connect to air hose. Fill with ~20psi of air. Detach the air hose line. Plug hole on ebay piece with finger. Then listen for leaks.
Old May 14, 2009 | 02:45 PM
VEGAS BAIL's Avatar
awesome that sounds good, Thank You
Old May 14, 2009 | 02:55 PM
No problem. The correct silicone reducer for that ebay part is 3.5" to 2.75"
awesomebang
Jul 5, 2017 08:48 PM
COBB Tuning
Jan 5, 2016 07:06 AM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
