Slave & Accumulator Changed = pedal stiffen
Old May 24, 2009 | 09:44 PM
Ben-G's Avatar
Ben-G has a spectacular aura aboutBen-G has a spectacular aura about
Exclamation Slave & Accumulator Changed = pedal stiffen
Changed the clutch slave master cylinder and pressure accumulator then bled the system (done by reputable indy). Now the clutch pedal has stiffen on start up, goes back to normal after start up. While driving the pedal is inconsistent, some times soft or other times as the pedal is being depressed it seems to stiffen up a bit, not as stiff as on start up. Any ideas what it could be?
Did a search here and renntech but no answers.
Is it possible that the new parts are defective?
Old May 25, 2009 | 04:56 AM
Colt45ccg's Avatar
Colt45ccg is just really niceColt45ccg is just really niceColt45ccg is just really niceColt45ccg is just really nice
Sounds like the system wasn't fully bled to me
Old May 25, 2009 | 05:07 AM
Mikelly's Avatar
You need a pressure bleeder, like a MOTIV to do it properly in my opinion... And yea, it's still got air in the system. Also, don't forget to check fluid levels in both the engine compartment and under the bonnet up front.
Mike
Old May 25, 2009 | 07:54 AM
Ben-G's Avatar
Mike
Thanks guys, will try bleeding it agian today.
Old May 25, 2009 | 09:10 AM
D_Nyholm's Avatar
D_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant future
Yes, make sure you fill the pump in the engine compartment. It'll take almost 3/4 can of pentosin. There are procedures for how to check the level in the manual. It has something todo with letting the car run for a short period and then checking it.
Old May 26, 2009 | 08:49 AM
Ben-G's Avatar
The power steering pump?, and I believe it's let the car run for 30 secs.
Old May 26, 2009 | 09:15 AM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
I replaced my accumulator but not the slave. I didn't have to add any pentosin.
Was I supposed to bleed the system at all??
Old May 26, 2009 | 10:11 AM
OCTurbo's Avatar
OCTurbo is infamous around these parts
If you start getting leaking from the front reservoir, then it's a faulty clutch slave. Porsche had a bunch of faulty replacement slaves. Make sure the clutch slave is 2008 or newer.
Old May 26, 2009 | 06:10 PM
D_Nyholm's Avatar
Yup, the power steering pump.. thanks
Old May 26, 2009 | 07:57 PM
Mikelly's Avatar
You should have had to replace the fluid in the old accumulator, and you absolutely should bleed it...
Mike
Old May 27, 2009 | 09:22 AM
Ben-G's Avatar
The system was bled again (yes with a pressure bleeder) and the same result???
Is there some sort of procedure to bleed this system?
Old May 27, 2009 | 09:23 AM
Ben-G's Avatar
Can I verify this with the slave on the car? Would there be some way I can tell by looking at the box...part number?
Old May 27, 2009 | 11:00 AM
OCTurbo's Avatar
My indy shop did the work, so i'm not exactly sure how they figured out when the slave was manufactured. It should either say on the box or you can call porsche with the part # and they can tell you.
Old May 27, 2009 | 12:13 PM
Mikelly's Avatar
It'll be a 997TT part number...
Mike
Old May 27, 2009 | 08:23 PM
Ben-G's Avatar
Date on part number on box - 05-04-2008
