I heard that RobMD did "close to 230 last year" in the mile . . . Congrats Rob!!!
Old Jun 5, 2009 | 10:28 PM
  #136
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Originally Posted by Craig
Apples and oranges. During the mile event (where the 4.81 was recorded), Joe's car was set up for a high speed run, including tires that plainly compromised his 60-130 time (stable tires with less traction). Joe was spinning his tires during the mile run well beyond 60 mph. With stickier tires (e.g., the DRs you used during your epic 60-130 runs), and better traction, Joe will run a much faster 60-130 time. Moreover, a fast 60-130 time requires specific, optimized shifting that is different from a mile run. A 60-130 run requires a specific lead in, at an optomized speed and RPM which cannot be replicated in an all-out mile run. There is little doubt that Joe will run considerably faster than 4.81 when he specifically attempts a 60-130 run, with the right tires, optimized lead in, optimized rpms and optimized shifting. Likewise, I have no doubt that Joe will attempt a 60-130 run shortly and immediately post his results.
Craig
Another reason and maybe more important than the ones Craig mentioned above is how the boost controller was mapped for the mile.We had the mapping for boost response set very soft so that it would not initially shock the suspension and tires at higher speed causing the car to be uncontrollable.This setting would greatly effect the 60-130 but not so the end result of the mile because most of the mile is spent in the last two gears above 6000 rpm where we were making full boost.
Old Jun 6, 2009 | 02:11 AM
  #137
If you want a 60 to 130 you need to specifically run it...
we pulled only a 5.2 out of the 9.9 sec 1/4 run...
best,
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
alevine
Nov 4, 2015 10:05 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Money2536
Sep 1, 2015 04:56 AM
rnl
Aug 26, 2015 02:36 PM
