Initial data from my EPL tial 3071s....(tune not complete)
Old Jun 24, 2009 | 08:06 PM
  #61
Prche951's Avatar
Originally Posted by ttboost
I can drop down to 75/25 with no problem, but have to retune for 50/50.
excellent. On hotter days, you might actually not loose power by going to that mix because of cooling.
Old Jun 24, 2009 | 08:55 PM
  #62
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
I picked up 35-40 awhp going from 50/50 to 100%.
Mike (or Tony if you are reading this), do you know what can be expected from going no meth to 100%?
Old Jun 24, 2009 | 10:34 PM
  #63
Zippy's Avatar
Great work Tony!
Mike
Old Jun 25, 2009 | 05:20 AM
  #64
ttboost's Avatar
Hey Dave, Tony can correct me if I'm wrong, but it seems I went from 520-530awhp to around 580-590awhp with the addition of 100% meth and the timing and boost along with it.
Old Jun 25, 2009 | 05:48 AM
  #65
Prche951's Avatar
worth doing for sure for that kind of power. Did you do a 60-130 before the mod. your 60-130 now is blazing.
Old Jun 25, 2009 | 05:56 AM
  #66
ttboost's Avatar
Yeah I think it was worth it. I was running 6.60's before, at the 520-530awhp level. I've yet to run another one in this heat and humidity, but have clocked a couple 6.3's. I've found a spot that isn't too bumpy and no traffic and fairly flat for 60-130's. I have also noticed that there is more consistency with the meth. When I do a few 60-130's in a row, they stay within a tenth or two now instead of having a 2 or 3 tenth spread, so maybe it does help with heatsoak a little.
Old Jun 25, 2009 | 05:59 AM
  #67
Prche951's Avatar
it probably does provide some cooling. you should try the 75/25 on a hot day and see what that does
Old Jun 25, 2009 | 06:04 AM
  #68
ttboost's Avatar
I did try it. I didn't notice any difference, seat of the pants, so I'll just leave it 100% for safety's sake, as I am running 1.4bar on pump.
Old Jun 25, 2009 | 06:15 AM
  #69
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
if you dont mind me asking whats the cost for that type of set up?
Old Jun 25, 2009 | 06:20 AM
  #70
ttboost's Avatar
The kit is around $650-$675, maybe a little more or less as they make improvements all the time. It will take about 6-8hrs to install if you have worked on your car before. If not, whatever your shop charges for 6-8hrs. The new kit is ALL plug and play now, except where it ties into the ECU. It has a few built in safety's too.
Old Jun 25, 2009 | 07:00 AM
  #71
MarkP's Avatar
MarkP has a spectacular aura aboutMarkP has a spectacular aura about
Originally Posted by str8blst
A group of us here locally GTG on a regular basis. Would love to have you join us! Maybe when MarkP is here next month we can get a group together. You going to Waterfest?
Hey Alan - I will be at Waterfest while I'm in NJ, then headed up to CT during the week and will likely be at EPL either 7/22 or 7/23 (Tues/Wed) before I make the return trip. Kieran said he'd be up for one of those afternoons at EPL... Hope to catch up with you at either/both...
Kieran, I'm looking forward to you making my car feel slow
Mark
Old Jun 25, 2009 | 07:28 AM
  #72
audikp's Avatar
audikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to beholdaudikp is a splendid one to behold
Calling Doctor Tony
Does the meth provide a good cooling effect on hot days?
in general...water is for cooling, meth is for octane...
Old Jun 25, 2009 | 07:29 AM
  #73
audikp's Avatar
Mark
It will be my pleasure
Old Jun 25, 2009 | 12:48 PM
  #74
audikp's Avatar
this is good info. Knowing that you are not likely to run out of the stuff. Now where do you buy it. Is it fairly easy to find?
I don't use washer fluid...I buy 5 gal pails of VP M1 at a local gas station that carries VP products. With a 50/50 mix thats 10 gallons of solution...so about 6-7 tank fills. The 5 gal pail costs me about $45-50 or so...
Old Jun 25, 2009 | 03:59 PM
  #75
Prche951's Avatar
thanks for all the info guys. I'd like to do this but I do not want to give up my current tuning.
