First GT2 DIY Oil Change: Impressions
Old Jun 25, 2009 | 10:20 AM
MTheory's Avatar
MTheory is a splendid one to beholdMTheory is a splendid one to beholdMTheory is a splendid one to beholdMTheory is a splendid one to beholdMTheory is a splendid one to beholdMTheory is a splendid one to beholdMTheory is a splendid one to behold
Originally Posted by mdd
Tom (TVERT):
Way too tight on the turbo drain plugs.
Here are the proper torques (from shop manual):
Crankcase - 52 ftlb
Oil Tank - 44 ftlb
Turbo Sumps - 22 ftlb
Filter Housing - 19 ftlb
In additon to the crush washers on each drain plug, there are 2 different O-rings in the filter housing that should be changed.
ColoradoSilver:
Cost for the filter, 4 crush washers and 2 O-rings was $15 last time I ordered from Sunset. 8 quarts of M1 will be about $50. So about $65 total.
Thanks for the info. I purchased my filter at the dealer and it only came with the big O-ring. I'll make sure to order from Sunset next time. BTW, your numbers on costs is about what I spent also.
Old Jun 25, 2009 | 11:03 AM
ColoradoSilver's Avatar
ColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud of
Tom (TVERT):
Crankcase - 52 ftlb
Oil Tank - 44 ftlb
ColoradoSilver:
Thanks for the information. I have a $50.00 off my next service cupon for my Porsche Dealer, so I may go through them for my next change. But in the future I intend on doing it myself. Good to know that it's easy to do and not so costly when you DIY.
Just have to get a good oil catch, or bucket from what I've read about.
Old Jun 25, 2009 | 12:48 PM
gt2rs's Avatar
gt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of light
Great writeup many thanks .
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
orbelo
Aug 30, 2015 12:26 PM
Lucid Moment
Aug 20, 2015 02:22 PM
