Clutch Accumulator question
Old 06-26-2009, 08:49 AM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
My clutch pedal gets really tight at startup and then while driving it feels close to normal. Does this indicate signs of Accumulator failure? I replaced my clutch accumulator about 4 months/4000 miles ago. Is it possible the same part is failing again? This replacement was done at the Porsche dealer and I am sure they bled the system well.
My Mechanic won’t be able to work on it till mid next week after warranty approval. I might go ahead and change the slave cylinder as well this time.
My question - is it okay to drive around this way for a couple of days or will it give up in traffic?
Old 06-26-2009, 09:46 AM
OCTurbo's Avatar
OCTurbo is on a distinguished road
no problem driving it around as long as there is not fluid leaking from the front driver side resevoir. This would be indicative of a clutch slave failure and this fluid is flammable.
Old 06-26-2009, 10:25 AM
vbmw335's Avatar
Thanks. I will check for leaks before i drive.
Old 06-26-2009, 10:58 AM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Had the same problem a few months ago. Keep the car close to home to be safe and carry a fire extinguisher if you must drive a long distance. OCTurbo is right the fluid is flammable.
Old 06-26-2009, 03:33 PM
sid350's Avatar
sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !
Clutch slave. Had the same problem, dealer did mine about 6-months ago. Accumulator was fine.
Old 06-26-2009, 04:30 PM
SXN's Avatar
SXN
SXN is offline
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
Is fluid overflowing from the front reservoir?
Old 06-26-2009, 06:08 PM
Macster's Avatar
Clutch failure... Tech cautioned me the other day that clutch hydraulics...
can go bad and one symptom is orange (IIRC) fluid at front of car. For some reason in some clutch failure modes fluid accumulates in power steering rack -- I know clutch hydraulics use same fluid system as power steerting -- and it leaks out at front of car.
Sincerely,
Macster.
Old 06-26-2009, 08:41 PM
vbmw335's Avatar
I checked for leaks under the car and around the reservoir ...no leaks anywhere. The pedal actually feels softer now and car runs fine. Not sure what the problem is ...i will get it checked next week.
Thanks everyone.
04-28-2022 12:38 AM
COBB Tuning
01-29-2022 09:42 AM
irish100p
08-31-2015 01:04 PM
ECS Tuning - VW
08-27-2015 02:44 PM
Quick Reply: Clutch Accumulator question
