Anyone lower their turbo to GT2 height?
yes I did it. I have PSS10's and the suspension was set at GT2 height, and the geometry of the components is perfect. No bumpsteer issues at all, in fact I could probably drop it another 20mm easy, if I was brave enough and did't car about my fenders
Stock
X73
GT2
If I remember correctly GT2 is 10mm lower than X73 which is 10 mm lower than stock. But that's off the top of my head. I know the dealer has all this information.
Would you mind measuring from the top of the wheel well to the ground so I have a reference point to shoot for? Thanks. Front and rear if you don't mind.
I'm getting ready for a major upgrade and want to set the height to GT2 level. With Motons it shouldn't be a problem.
I can do that but you have to realize that those measurements will change with tires/wheel type and wear. And also every corner is different from factory so you have to bring the measurement down as a difference. I think I read somewhere that the best way to measure is from the bottom of the fender center to the center of the hub. I think Mike Kelly has a good thread on this as well. But I will measure and give it to you.
I think most people use wheel well to ground, but this is from Porsche. You'll have to double check the specs.
the 25.25 sounds familiar. I think one side is that for me as well. I will measure mine as well.
There might be some helpful info in this old thread: Bilstein PSS-9's Do Not Mix With GT2 Ride Height - The Write-Up
Greg A
Greg A
