03 x50 only pulls to .4 bar?
Old 07-02-2009, 08:12 AM
SIC996's Avatar
SIC996 will become famous soon enough
A friend of mine has a x50 with 24k miles and it only pulls to .4 bar in 3rd or 4th it runs great and no codes but will not go past .4. He has tried disconnecting the battery, should it just have a boost leak test or would that be DV's?
Old 07-02-2009, 08:25 AM
wross996TT's Avatar
How do you know there are no codes? Did you use a PIWIS, PST2 or durametric? There does not have to be a light on for codes to be logged. The possibilities are leaks, DVs, wastegates...etc.
Old 07-02-2009, 10:11 AM
SIC996's Avatar
Durametric shows no faults stored.
Old 07-02-2009, 10:30 AM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
Like wross advised, check boost hoses, especially around the intercoolers and diverter to hose connections, sounds like a boost leak somewhere.
Old 07-02-2009, 10:35 AM
ColoradoSilver's Avatar
ColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud of
Leakage. Check your seals, DVs, connections, and look for splits in the hoses. The stock F-hose has been known to split.
Old 07-02-2009, 10:54 AM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
.4 is typically referred to as "limp mode" which is what the car goes into when there's a leak...It was designed into the computer to protect the engine and to alert the driver that something is wrong. Blowing a hose off the intercooler will cause this...F hose leaks or poor/loose hose fittings will cause it. Did your friend do anything to the car recently....like, install diverter valves etc? If so, check the recent work, If not, then look for the leaks.
BTW....if it turns out to be a hose to the intercooler or boost hose....don't be afraid to spray a little WD40 on the connection and wrestle the hose back into the connection till you hear it click. I spent hours taking everything apart and messing with the wire clip...then took it to an indy who simply grabbed the hose intercooler hose, jammed it in and yanked on it like he was pulling a bad molar...and I heard the wire clip "click" as the hose snapped into place. He did in one minute what I had taken hours to fiddle with because I was using a white glove approach.
Old 07-02-2009, 10:55 AM
VEGAS BAIL's Avatar
VEGAS BAIL is just really niceVEGAS BAIL is just really niceVEGAS BAIL is just really niceVEGAS BAIL is just really niceVEGAS BAIL is just really nice
my first guess would be a boost leak, definitely check that
Old 07-02-2009, 11:21 AM
SIC996's Avatar
Thanks, he dropped the car by so we'll check for loose hoses and then do a pressure test. I was wondering why it just stayed at .4 but that answered my question that a boost leak can send it to limp mode. Thanks again
Old 07-08-2009, 08:22 AM
SIC996's Avatar
ok, no boost leak and no codes? could it be dv
Old 07-08-2009, 08:35 AM
Prche951's Avatar
I would check DV's and wastegates. and I would check them pronto. Check the wastegate adj nuts.
Old 07-08-2009, 09:57 AM
tom kerr's Avatar
last time mine did this one of the actuator rods was broken and it was running on one turbo.
Old 07-08-2009, 10:12 AM
SIC996's Avatar
rods look fine, could he have a bad turbo? and how would you check one?
Old 07-08-2009, 10:46 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Easy, just take of the intake pipe going into the compressor housing inlet and look at the wheel for damage. You will also want to check the shaft play by holding the center of the wheel and moving it up and down.
Old 07-08-2009, 10:49 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Check for boost leaks before suspecting a bad turbo, its far more likely.
Old 07-08-2009, 11:47 AM
sleepys4's Avatar
sleepys4 is on a distinguished road
Similar problem here, except I was hitting 1.0 bar yesterday. Could there be something wrong, its a stock turbo S.
Quick Reply: 03 x50 only pulls to .4 bar?
