Brake pads for $34? Has anyone tried them?
I need to replace my rear pads and found that pelican parts has a set of Mintex for $34 - Let me know if anyone has tried them an opinions.
http://www.pelicanparts.com/cgi-bin/...2D%30%35%29%20
not sure of op but squeeling is my number one thing i want to get rid of with street pads, any other recommendations besides oem?
high performance pads are going to squeal like a banshee until you get them nice and hot
Ok im back and have installed the front mintex as I had no time for the rears tonight. My mini review:
I had pagid oranges that squeeled like a metro bus picking up an army. So I said what the hey and purchased a set of mintex redbox. It came today and I began to install the fronts.. after reading the DIY I thought it would be easy but the dampers just wouldnt come out so I had to do with what I had and cleaned them from there and left them. Cleaned up the pads, stuck some "brake quiet" on the back of the pads evenly but then putting a little heavy on the inside of it because I knew it was going to scrape along the damper(Vibe pad) when sliding in. Did it for both sides. Zip tied up my brake sensors and called it a day. Went out did the bedding (WHICH I THINK IS SUPER CRUCIAL for not squeeling) and after my bedding......NO SQUEEL
well except a tiny bit from the rear but ill tackle the rears tomorrow.
So in short here are my tips:
1. BEVEL the edges on the new pads!! Dont know if this helped but it obviously didnt hurt.
2. Clean both the back of the brake pads and the vibe pad.
3. Apply the "brake quiet" evenly on the pad or how it will end up evenly on the pad.
4. BED the pads CORRECTLY!!! I have been reading that if bedded correctly even Pagid pads can become squeel free!
Overall results: Quiet up front, tiny squeek in rear from pagid oranges.
Cons: Not as strong of a bite as the pagid oranges were in the front but i'll survive
well except a tiny bit from the rear but ill tackle the rears tomorrow.So in short here are my tips:
