Replaced lights to LEDS
Old Oct 13, 2011 | 08:25 PM
  #106
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Originally Posted by bfk4lyfe
Does anyone know if its possible to replace the stock turn signal bulbs with leds without getting the stupid fast blinking? I bought some pep boys ones that a friend had good luck with and they blink normally when you put on the 4 way flashers, but if you turn on the left or right it does the hyper blinking.
A load resistor will solve that issue.
Old Jun 4, 2012 | 07:51 AM
  #107
XLR82XS's Avatar
I finally got around to finding a good LED bulb for the tail/brake lamps. Illumination day and night is equal to, if not a tad brighter, then OEM. Purchased from www.autolumination.com
Old Jun 5, 2012 | 12:12 PM
  #108
Slider's Avatar
So, which light does the part #(1157-R45-T) replace and which one is it (left or right)?
Old Jun 5, 2012 | 12:59 PM
  #109
XLR82XS's Avatar
Offset pin (dual filament) is the brake light. Single contact bulb is the running lamp next to brake light.
cadman
Nov 13, 2025 08:57 AM
COBB Tuning
Jan 1, 2025 09:02 AM
Jeff1smith
Aug 19, 2015 09:41 PM
