Where to buy Mobil 1 5-50
Old Jul 18, 2009 | 10:17 AM
JD's03tt's Avatar
JD's03tt is infamous around these parts
In Florida
JD
Old Jul 18, 2009 | 10:26 AM
MBailey's Avatar
Any Porsche dealership should be able to get it for you.
Old Jul 18, 2009 | 11:03 AM
ard's Avatar
ard
Say what?!?!?!
Call Mobil and ask, 5-50 is limited distribution. Not every Mobil 1 distributor has it, and most retailers dont even show it on their 'available to order' list
Old Jul 18, 2009 | 12:52 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
ard how does your umw flash compair , can you reflash for 91 oct thanks steve
Old Jul 18, 2009 | 12:54 PM
ye i can spell compare
Old Jul 18, 2009 | 01:43 PM
ard's Avatar
ard
Hey Steve...
So, first- there is a button on every post you make that says "EDIT"...try it. You can go back and correct your posts!!! Even change cApiTaliZation and -p*$unctu^%ation. (I kid, I kid.)
Compare to...? Compared to stock? No comparison. I added an EP2 and wastegate kit about 3 days before the flash- only drove it a bit, It was stronger with the stock program (and the EP2/wastegate) but not very well behaved (lean, jumpy, etc)
Then I added the UMW flash. WOWOWOWOW. Much more power, much more linear and well modulated- just like a stock feel, but less lag, quicker throttle, and 20% more power!
I have a UMW 100 octane flash as well. Rarely used.
Most of the time I run the UMW standard performnace flash, but run 95-96 octane. The DME will advance the timing and will make use of the higher octane without reprogramming.
Adam
Old Jul 18, 2009 | 02:20 PM
MBailey's Avatar
Originally Posted by ard
Say what?!?!?!
My dealer ordered it. It showed up in two days.
Old Jul 18, 2009 | 03:53 PM
ard's Avatar
ard
I guess I'll drink (a quart) to that!
I've never heard of a dealer having it. Being able to order might depend on their local stocking distributor. Good to know though-
A
Rguy
Apr 12, 2020 11:11 PM
DB-Design-Group
Group Buys
46
Nov 3, 2015 11:27 AM
Risley
Sep 6, 2015 03:31 PM
igdawgi
Sep 4, 2015 07:05 PM
