Intake Plenium
Old Jul 20, 2009 | 11:19 AM
  #31
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Wow Ben,
That is a significant difference on a stock tip.. Nice.
Old Jul 20, 2009 | 11:44 AM
  #32
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
RSS, thank for the update!! That is a pretty significant difference. It actually improves turbo spool and the whole curve has almost been elevated which is increase in power. Finally, the whole message I've been trying to get across for the past two years are coming to life
Old Jul 20, 2009 | 11:58 AM
  #33
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Ben: Thank you for posting the dyno results. There has been a lot of speculation about how much advantage there really is to installing the plenum, and this breaks into the TT market...however, I think that the majority of us out here who have modded our cars fall into the category of having the upgrades include a flash, DVs, some sort of free flowing exhaust system, the wastegate kit, and possibly a hybrid turbo. Whereas I realize you can't possibly conduct a test given all the possible variables, is there any way you could do a dyno on ....let's say a "basic" or generalized modded car that has a flash and some upgrades that put it into the most common category of 550-600 crank HP? There is a pretty substantial market of folks out there who fall into this category...me being one of them. If I had some assurances of a definitive improvement of 30-40 hp iin a "basic" modded TT, I'd be inclined to go with one.
For the engineers in the crowd....can you extrapolate the results of the dyno results from the tip and make any projections about what would occur with a modded car?
Old Jul 20, 2009 | 12:39 PM
  #34
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Well, this is obviously a hot topic, so much debate means there must be something out there, RSS Ben, those stock TT Tiptronic results were on a stock 60 MM TB ? The only thing which potentially stops me going there is the labor will probably cost me as much as the parts aka my Pss9's ?
Old Jul 20, 2009 | 01:43 PM
  #35
Betim@BBIAutosport's Avatar
Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !Betim@BBIAutosport Is a GOD !
I have the IPD plenum on my personal 996TT. My butt dyno noticed gains using their 70mm. I recently upgraded to their 75mm setup and on my 750hp turbo I noticed substantial gains. I would recommend 70mm for 600hp and below, and 75mm for anything higher. Most of our customer cars have them, and we highly recommend this upgrade for mid-high hp applications. The install time on this is around 3 hours. +1 To Turbo Mike
Old Jul 20, 2009 | 02:13 PM
  #36
RSSsales's Avatar
RSSsales is infamous around these parts
Hi RichardCH,
The dyno testing was done on a bone stock 2002 996TT Tiptrpnic. I also noticed you mention a 60mm throttle body. The 996TT comes standard with a 70mm throttle body.
Installation time for a Porsche Technician is aporximateley 4 hours.
If you haver any additional questions please give me a call at 714-545-1046 or shoot me a PM.
Ben@RSS
Old Jul 20, 2009 | 08:15 PM
  #37
John@SpeedTech's Avatar
I have done this myself and would concur that it is about a 4 hr. job, if all goes well. Be sure the rubber boots are aligned perfectly and the clamps are straight and secure. It is important to pressure test it. I had a leak the first time and had to go "back in" to re-align and fasten the rubber boot on one side, which was not seated properly. It was a little tricky for me to get both sides on just right, as when I put one side on good, the other side pulled off a bit and vice versa. In the end, I found a method that worked - as long as you know this going in and are aware of it, you should be fine. I would allow the better part of a day or long night and it will be done.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jul 20, 2009 | 08:37 PM
  #38
Originally Posted by John@SpeedTech
I It is important to pressure test it. I had a leak the first time and had to go "back in" to re-align and fasten the rubber boot on one side, which was not seated properly. It was a little tricky for me to get both sides on just right, as when I put one side on good, the other side pulled off a bit and vice versa.
tell me about it LOL
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 20, 2009 | 08:47 PM
  #39
:-) yea, a little frustrating when it happens, but like anything else - once you've done it, it's a lot easier the second time around...now it's just a distant memory and all is good.
2022 Cayenne White
Old Jul 21, 2009 | 12:10 PM
  #40
RCH's Avatar
RCH
Hmmm as I noted labor is as much as the part unfortunately, if you had to drop the engine for whatever other reason, would that halve the time ?
Old Jul 21, 2009 | 12:16 PM
  #41
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
It doesn't require a full drop; a partial drop would do which is not much work.
Old Jul 21, 2009 | 12:30 PM
  #42
MBailey's Avatar
Did not drop at all. Took about 4 hours. Labor should be less than the part.
Old Jul 21, 2009 | 12:31 PM
  #43
Just talked to Turbo Mike. I'm getting this mod.
Old Jul 21, 2009 | 12:37 PM
  #44
art4iza's Avatar
If I tell you that TurboMike can do it in less than 2 hours, believe me. With everything intact and a cigarette in his mouth while talking to me LOL. He is one of the best there is....do not race with his big boy, silver 993tt....with only 10 lbs he will peel away like you are standing still
Old Jul 21, 2009 | 03:40 PM
  #45
No drop about 4 hours. If the engine is out, I would guess about 15, maybe 20 minutes.
2022 Cayenne White
ECS Tuning - BMW
BMW Vendor Classifieds
Oct 1, 2015 03:30 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
