Intercoolers 996 TT
Old Jul 31, 2009 | 07:48 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Intercoolers 996 TT
at what stage is it worthwhle changing Intercoolers and who has the best OEM alternative for the best price please ? what is the time labor
Old Jul 31, 2009 | 08:09 AM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
get a hold of palette. He has a set of awesome b6's that are direct bolt on. I personally ran 10 sec 1/4's with basic 18g set up and those suckers in there. Actualy I think you can score the pkg from him too!! although his is a 20g set up which would kill my set up!! Not that 10.8's and 10.90's are anything to laugh at but ... HE HAS IT FOR SALE NOW!! Scoop it before someone else on board does!!!
Old Jul 31, 2009 | 08:10 AM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Marski has a set!
Old Jul 31, 2009 | 08:14 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Thanks Dio!
Richard send me a PM if your interested.
Link below
Old Jul 31, 2009 | 09:47 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Upgrading your stock intercoolers is an often overlooked, yet very sensible mod at any stage of the game.
Because we're firm believers that EVOMS has got the 996 platform dialed in, we suggest upgrading to the EVO Clubsport coolers. The cores are over 30% bigger then the stock units, and they flow up 49% more air. The benefits are numerous....cooler IAT's, quicker boost response. Feel free to let me know if you have any other questions.
http://www.rennsport-one.com/activac...&ProductoID=49
Old Jul 31, 2009 | 10:02 AM
WOODTSTER's Avatar
What thickness are the new are the EVOMS clubsport?
The end caps look terrific !
Old Jul 31, 2009 | 10:17 AM
The cores are 33% larger then the OEM GT2 cores. The end caps are quite impressive as well. The inlet side has about 200% more volume the then OEM coolers, and the outlet side has about 60% more volume. We're talking créme de la créme here.
Old Jul 31, 2009 | 10:21 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I'm running the Agency Power IC's from Vivid Racing. Call Dan and he'll send them today.
460-628-8073 x222
Old Jul 31, 2009 | 10:25 AM
vividracing's Avatar
Yep we got ours on special too. See the 996TT vendor classifieds. I also have 2 sets of 997 Turbo OEM IC's and 1 set of GT2 for sale.
Old Jul 31, 2009 | 07:13 PM
MBailey's Avatar
It depends on your climate and other mods to determine if aftermarket ICs will help. If your climate is very very hot (100+ summer) you may benefit from ICs with stock a configuration. I live in a fairly hot area and I upgraded to EVOMS Clubsports after I hit the 600 crank hp level. I did not notice a huge increase in power but the car was much more consistent and ran farther before heatsoaking. It also a good way to protect your engine from detonation especially with aggressive tunes.
Also has you move up the hp ladder you will find stock ICs will not pass high levels of boost well (IOW they are fairly restrictive). So if your ECU is programmed to deliver 1.3 bar of boost at higher rpm the stock IC may be restricting amount of air so that the turbo never can reach that level of boost or has to work harder to get there (which means more heat and lag). I noticed my high rpm boost went up 0.1-0.2 bar in fourth gear and above just by changing ICs.
If your other mods include meth injection you may not benefit much from ICs because meth cools IATs down dramatically by itself. You might only need ICs in that situation to lower boost restriction.
The labor was about 4-5 hours for me.
Old Jul 31, 2009 | 11:10 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
It would help to know what mods you've done to your car. If you're running a flashed K16 and not in the boost for extended periods of time I'd say you're OK with what you have. Yes, upgraded ic will help with a lot of things but at what point you really need to upgrade depends on a lot of variables. For instance, how you drive, climate, do you race (road or 1/4 mile), boost you're running, type of turbos yadda yadda yadda.
If you do want to upgrade I think the set Palette is selling is very good and a good price. Also, Markski has some top notch intercoolers if you're considering going larger.
If it helps I've been running a Proto K24/18g setup with my stock ic for the last year. I am upgrading to some much larger high end intercoolers soon though.
Old Aug 2, 2009 | 12:01 PM
RCH's Avatar
RCH
tx. for the input, does the 996TT have exactly the same intercoolers as the 996 GT2 ??
Old Aug 2, 2009 | 12:13 PM
unvmy996's Avatar
no the Gt2 ic's are slightly different .
Old Aug 2, 2009 | 02:02 PM
RCH's Avatar
RCH
tx. exactly what is that diff. pls ?
Old Aug 2, 2009 | 02:33 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Don't bother with the GT2 intercoolers. I doubt you will find anyone advocating them unless they are trying to sell them to you.
As others have pointed out, climate and mods are keys to consider. So what do you have and where are you located?
