275's on 9.5" wide CCWs are ok up front, right? ;-)
Old Aug 17, 2009 | 04:43 PM
itacud's Avatar
itacud is a jewel in the roughitacud is a jewel in the roughitacud is a jewel in the roughitacud is a jewel in the rough
I believe Al Norton uses this setup with Hoosiers... but I'll be using Nitto NT-01's, which look to be even wider than R6s, in 275! (10.91 section width for the 275/35/18 NT-01s, 10.7 for the R6s). I'll be using an offset of 45mm on the 18x9.5 rim or about 7" backspacing, in CCW speak. I'll know in about a week if this setup fits... Fingers crossed, or it's an expensive mistake!
I'm using -3.0 deg of camber in front right now, 2.5" diameter springs, etc... Might be able to do -3.25 if more clearance is needed, though I'm not yet sure. The inside of the fenders are rolled... though I can't flare them any wider than stock according to class rules.
Any words of warning before I let CCW start building this order tomorrow? =)
Old Aug 17, 2009 | 06:11 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
are you worried about the tire rubbing on your shocks with -3.25 camber?
Old Aug 17, 2009 | 06:44 PM
itacud's Avatar
Actually, I was more worried about the outside clearance, at the fender. =) But, I should probably check the inner clearance right now, also...
Old Aug 17, 2009 | 06:55 PM
cjv's Avatar
cjv
Moderator
I mounted 265 PSC and 275 Hoosiers on 10 x 18 Fiske wheels. I got a ever so slight rubbing on the inside frame (about a 1" long area) by the back of the wheel when turning either right or left at full lock. We used 12.5 x 18's on the rears.
Old Aug 17, 2009 | 07:39 PM
tom kerr's Avatar
I run my front Hoosiers 275's on a 9 inch rim.
Old Aug 17, 2009 | 08:14 PM
Chasen1211's Avatar
Chasen1211 is a jewel in the roughChasen1211 is a jewel in the roughChasen1211 is a jewel in the rough
cant wait for you to see how the 275 works on the c4s! will you be at the sept5-6 thill event? will try to make it there!
Old Aug 19, 2009 | 04:32 PM
itacud's Avatar
Yeah, I'll be at THill. I actually decided to order 265 PSCs instead of the NT-01s. I still have a lot of suspension setup to do, to get the car competitive again!
Old Aug 19, 2009 | 04:34 PM
itacud's Avatar
Where exactly is the rubbing you see occurring? Not quite sure where the inside frame is.... Do you mind sharing your wheel offset or backspacing specs? Thanks! I imagine that 10" width might be just over the limit of what can be squeezed in the front wheel well?
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Mar48
Aug 24, 2015 01:13 PM
