Project: Plenum, TB, Intake piping and fuel pump
Old Aug 27, 2009 | 01:58 PM
  #106
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Yea, we are datalogging in a few minutes.
Old Aug 27, 2009 | 02:03 PM
  #107
MBailey's Avatar
Also I would double check that new fuel pump to make sure its hooked up and working properly.
Old Aug 27, 2009 | 03:18 PM
  #108
Update: passenger side tube is collapsing flat under boost. Good news is that before it shuts down, torque is at 620lbs. Going in with a stint in that spot tomorrow.
Old Aug 27, 2009 | 03:28 PM
  #109
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Be careful with ANYTHING you put in front of the turbo or it will end up like my old 3071's..
Old Aug 27, 2009 | 03:58 PM
  #110
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Todd,
That is a problem with using the silicone hose that isn't reinforced and gets worse the bigger the turbo.The problem with putting a stint in it is not just worrying about getting anything sucked in the turbo it is that with that much length of hose it will probably get sucked in somewhere else.The Ford Gt's have a similar problem with the stock inlet after putting on a bigger Supercharger.You should see if you can get hard piping.Joe
Old Aug 27, 2009 | 04:03 PM
  #111
joetwint's Avatar
Originally Posted by vividracing
Other other option is that craziness prototype part you installed is leaking, but that would not make sense if you did a boost leak test.
Dan That part is not under pressure ......and not part of a boost leak test as it is before the turbos
Old Aug 27, 2009 | 04:15 PM
  #112
Thanks Joe, I'll talk to the manufacturer!
Originally Posted by joetwint
Todd,
Old Aug 27, 2009 | 05:54 PM
  #113
Prche951's Avatar
question is can collapsing the intake tube and starving the compressor cause any excessive loads on the compressor wheel bearings? or anything else? that would cause problems.
also, how did you know this was happening? good to find out early.
Old Aug 27, 2009 | 06:01 PM
  #114
We could see it thru the wheel.
Old Aug 27, 2009 | 06:03 PM
  #115
Prche951's Avatar
That's right this was on the dyno. I was thinking on the road. Still, if those suckers weren't the color they are, you may not have seen them at all.
Old Aug 27, 2009 | 06:08 PM
  #116
You're right. I hope to have her on the road this weekend.
Old Aug 27, 2009 | 06:13 PM
  #117
Prche951's Avatar
congrats on getting her on the road. Downtime sucks.
Old Aug 27, 2009 | 06:19 PM
  #118
Thanks man. It sure does.
Old Aug 27, 2009 | 06:42 PM
  #119
John@SpeedTech's Avatar
IMO, The EVOMS hard piping or equivilent is the only way to go on this mod. It's thicker and stronger than the OEM piping and quite larger. A very well designed piece that will survive intact over time.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Aug 27, 2009 | 06:45 PM
  #120
ttboost's Avatar
another tip, if you have the room, is to use T-bolt clamps, NOT hose clamps. NEVER pop off and NEVER come loose...
