clutch when starting
Old Aug 26, 2009 | 04:58 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i have to push my clutch right to the floor in order to start the car but once its running the 'bite' point of the clutch is much higher
is this normal, can it be adjusted ?
Old Aug 26, 2009 | 05:02 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
they are all that way as far as havin to pusch the clutch to the floor to start. if you slide your floormat forward under the clutch pedal it should not start
Old Aug 26, 2009 | 05:57 PM
wross996TT's Avatar
there is a switch under the clutch which must be depressed to let you start the car. Unfortunately there is no adjustment per se for a hydraulic clutch...though you could try bleeding the system...
Old Aug 26, 2009 | 06:46 PM
jpflip's Avatar
Clutch switch cannot be adjusted but on this picture you can see the location (item #17) . If you don't found anything wrong ( bend bracket or loose switch or mount) just replace it . It is less than $15.00.... Part# 99661311401
Old Aug 26, 2009 | 07:09 PM
buzzm's Avatar
problem solved, if you connect the 2 brown wires from the switch together you can start the car without having to depress the clutch at all
Old Aug 26, 2009 | 07:54 PM
jpflip's Avatar
In fact I don't think ROW cars got that switch.... Only in North America !
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
AuZZie
Sep 2, 2015 04:26 PM
pjb84
Sep 2, 2015 12:57 AM
