Does anyone rebuild wastegates?
Old Aug 27, 2009 | 03:15 PM
John@SpeedTech's Avatar
I have wastegates with the upgraded springs and I recently had to turn one of them quite a bit more than the other in order to get even opening. I think one has a failed diaphram.
Does anyone here rebuild/repair wastegates?
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Aug 27, 2009 | 06:13 PM
ard's Avatar
ard
How much 'quite a bit more'? As I recall, the sides should be 'off' by 1.5mm or so, which can be a bunch of turns.
If a diaphragm has a hole, it will not hold pressure period, and will not open. You would also get air rushing out of the hole around the shaft.
my 2 cents. I'd check with some turbo vendor/tuners for spares... one I spoke to said they sometimes have a few.
A
Old Aug 27, 2009 | 06:33 PM
ard,
Previously, the both wastegates were set-up to crack at the same pressure. Something changed with one of them and it required turning the nut 1/2" to get equal opening again. Something is wrong with that wastegate, maybe I have a broken or worn out spring - I am not sure exactly what it is..I am looking for someone that can take it apart, identify the problem and properly repair it.
2022 Cayenne White
Old Aug 27, 2009 | 07:00 PM
ard's Avatar
ard
One half INCH? Yikes... Which way did you need to move the rod?
I think if your spring broke, then there is less resisting force, and you would have had to move the adjusting nut towards the wastegate (thereby pre-loading that broken spring back to where it should have been).
I did Kevins kit, twice...did it for another 6speeder. No special wastegate parts here (other than 4 stock springs )- and that diaphragm is indeed a bit unusual.
With the UMW kit, you can just disassemble and look inside... I assume yours are some other kind?
GL
Adam
Old Aug 27, 2009 | 07:15 PM
Adam,
It had to be tightened towards the wastegate.
I have the UMW wastegates with the aluminum clamps, so I will be able to open them easily and look inside - I just want to be sure if I open them, that I have someone in place to repair them.
2022 Cayenne White
Old Aug 27, 2009 | 07:41 PM
ard's Avatar
ard
Should be stainless clamps.
I am pretty sure Kevin would send you a spring, maybe even before you open them just in case. he might even have a spare diaphragm w/rod.
GL
A
Old Aug 27, 2009 | 08:43 PM
Adam,
It is whatever metal Kevin uses for the two piece clamp. I have emailed Kevin, as I purchased the product directly from him, but I received no reply, so I am trying to find someone that can handle this for me. The car is running fine and remains balanced, but it's something I feel should be done before it needs adjustment again.
2022 Cayenne White
Thunder915
Oct 1, 2019 07:34 PM
alpha motoring
Oct 2, 2015 12:04 PM
DYL 911
Oct 1, 2015 02:47 PM
panas001
Sep 27, 2015 02:51 PM
