Light weight BAttery
Old Aug 31, 2009 | 12:07 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Originally Posted by teflon_jones
I went with the Sears battery for daily driveability. I travel a good amount and don't want to keep a trickle charger on the car but it still dropped 20 or 25 lbs off the weight of the OEM battery.
Which model did you go with? I tried the lightweight route and it was more of a PITA than it was worth.
Old Aug 31, 2009 | 10:31 PM
John@SpeedTech's Avatar
Don,
Which battery did you try?
Is there a good LW battery (say 25 Lbs or so) that will not be a pain, but will still shave some significant weight vs. the OEM? I drive my car almost every day.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Aug 31, 2009 | 10:52 PM
dgreen78's Avatar
Originally Posted by john@speedtech
don,
which battery did you try?
Is there a good lw battery (say 25 lbs or so) that will not be a pain, but will still shave some significant weight vs. The oem? I drive my car almost every day.
pc680
Old Aug 31, 2009 | 11:00 PM
drnano's Avatar
drnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to behold
I have the Odyssey PC925. It is 5lbs more than the 680 but holds its charge for a week no problems. It also saves 26.4 lbs over the stock battery.
Old Sep 1, 2009 | 07:39 AM
WOODTSTER's Avatar
Originally Posted by heavychevy
Yep. At least for the lightest ones, which most of which are made for 4 wheelers and recreational vehicles. Plus the cranking amps are pathetic. You'll have to live on the trickle charger.
I have the lightest/smallest Odessy and really cool lightweight bracket.
My car lives on a trickle charger. OK for limited use but not OK for Daily
Driver. Pathetic cranking power.
MK
Old Sep 1, 2009 | 08:13 AM
Prche951's Avatar
is it worth the weight savings to shorten the life of your alternator? I have a battery that weighs more than the original, it could probably start a battleship, but at least I know my alternator has little work to do, and the windings will not overheat repeatedly causing failure to come sooner.
Old Sep 1, 2009 | 08:25 AM
supergoji's Avatar
supergoji is infamous around these parts
i got the braille auto racing battery that weighs 15lbs.
used it through out the winter in my 300zx. no problems.
dry cell, more power than a acid battery, you can mount it anywhere.
and it's a deep cycle battery too. (meaning you can run it dry and recharge it with no ill effect)
my Z has a 3.0l V6. you guys have 3.4-3.8 engines so idk if the battery has enough power to crank over your engines or not.
my Z is daily driven.
Old Sep 2, 2009 | 02:43 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
I guess I am looking for a compromise that it is a little more durable that PC925 but not OEM, guess I should try the Odyssey PC1200 which is 16KG vs 11KG
Old Sep 2, 2009 | 09:01 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
are optima batterie any lighter? the red tops?
Old Sep 2, 2009 | 10:43 AM
ttboost's Avatar
I am going to pick up a Deka ETX14 today...gonna try it...
Old Sep 2, 2009 | 11:16 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
I don't remember the exact model but if you search on here you should be able to find it. It's an E series but I don't remember the model number (92 maybe)?
Old Sep 2, 2009 | 12:32 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
I just removed one of the expensive little Braille batteries with bracket and went back to my Optima 35. too many cranking problems with the little one.
It's for sale if anyone wants to buy some trouble.
Old Sep 2, 2009 | 05:42 PM
raidentech's Avatar
raidentech is infamous around these parts
Nothing compare to this 3lb battery from Voltphreaks
http://www.voltphreaks.com/
High quality batteries. I have it on my car. No problem for 2 years.
Old Sep 2, 2009 | 09:14 PM
ttboost's Avatar
Holy crap!! A $1300 battery????!!!! I'm good. I got my $72, 11lb battery in tonight. I'll try it and see how it goes...stock battery was 49lbs..saved 38lbs with this mod...
Old Sep 3, 2009 | 08:17 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
let us know how it is.
I was looking at the specs but not convinced on it yet..
"Product DescriptionDeka ETX14(1) Battery Replacement
The Deka ETX14(1) Battery cross-references to the following:
Adventure Power UTX14 Battery (YTX14-BS Compatible) ManufacturerAdventure PowerModelAdventure Power UTX14 Battery (YTX14-BS Compatible)Weight9.92Volts12Amp-Hour12CCA160Length5.98Width3.46Height5.78Warranty1 YearChemistrySealed AGM Lead AcidPolarity| + |||||| - |
