Replacing DVs
Old Sep 9, 2009 | 11:09 AM
GoingFast's Avatar
GoingFast is infamous around these parts
Replacing DVs
Should I replace my DVs since I jus passed 50K on my car? They are fine, but eventually I will have to replacement. The car is in the shop and getting some work done. All works are covered by the aftemarket warranty. Does anyone know if warranty will cover the DVs even though the DVs are still good. A white lie by my mechanic won't hurt, right? The warranty expired in March 2010 and I figured I get as much out of it as possible.
Thanks,
TC
Old Sep 9, 2009 | 03:11 PM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
It sounds like you're suggesting have the DVs replaced with another set of stock DVs...is that correct?
Old Sep 9, 2009 | 03:25 PM
GoingFast's Avatar
Good question! I was thinking AWE DVs and make up the price difference if there is one since I might get a flash next year.
Old Sep 9, 2009 | 04:16 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i just got a set of bailey dv's as they dont need yearly servicing, if you are planning on modding ( which as soon as you drive mine at c&c you will ! ) then you should upgrade the dv's, so you may as well do it now
there are people running stock dv's after modding though so you might be fine but personally i wanted to upgrade
Old Sep 10, 2009 | 07:24 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
replace those old stock dogs with somthing good their are lots to chose from i've had forge ,evos.and both have worked fine for me
Old Sep 11, 2009 | 06:48 AM
Ray C.'s Avatar
Ray C. is infamous around these parts
My warranty covered the original "failed" DVs. You will need them changed to support a decent tune.
Old Sep 11, 2009 | 10:06 AM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Old Sep 11, 2009 | 03:26 PM
buzzm's Avatar
does lowering the engine avoid having to remove some of the other pipes necessary to get to the dv's ?
Jun 10, 2017 07:45 PM
AdamNoone
Aug 31, 2015 07:45 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 24, 2015 09:29 AM
Jeff1smith
Aug 19, 2015 09:41 PM
