This sucks done everything
Old Sep 17, 2009 | 02:44 PM
CayenneOFDeatH's Avatar
CayenneOFDeatH has a spectacular aura aboutCayenneOFDeatH has a spectacular aura aboutCayenneOFDeatH has a spectacular aura about
Exclamation This sucks done everything
well long story short my 996tt is running 1.3 boost bar with K24/18G turbos , exhuast , headers , air intake , boost hoses , Dvs , softronic flash , IPD plenum and 5 bar fuel regelators .
Thought id kick it up a noch so i sent her to garage to fit in High flow intercoolers , Fvd Plenum pipe , 60lb fuel injectors , Greddy Boost controler and to put back in the 3.8 oem fuel regelator so i can flash it using softronic flash got the car back but it was running 0.4 bar max
thought the problem was from the boost controler so i removed it yet still no boost so i sent the car to another garage removed the fvd plenum still no boost thats when i got frustrated and asked them to remove the injectors too and to fit in the 5 bar fuel regelator to get my car to where it was before ( 1st mod list but with the high flow intercoolers ) yet there was no boost
Please help since my car have been in and out of garages for the past 3 months ;(
Many thanks
Old Sep 17, 2009 | 02:57 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Maybe your MAF is blown and you're in limp mode. Pull the MAF out and see if you can boost. IF so, replace MAF. The 60LB inj work fine with the 3.8bar so thats not your problem. One other thing is, disconnect battery for 15min. Reconnect and start it up.
Old Sep 17, 2009 | 03:20 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
checked the boost transducer/solenoid to see if its broken for the factory DME?
Old Sep 17, 2009 | 04:21 PM
ttboost's Avatar
not to state the obvious, but you said you did intercoolers? Did you check for leaks? boost hoses pop off all the time.
Old Sep 17, 2009 | 06:11 PM
Pressure test the car from the turbos..
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 18, 2009 | 05:41 PM
i'll try that tomorrow , but could u elaborate more about the battery thing would it affect the flash , about the 60lb inj it said on the email they sent me dnt flash if u have the 5 bar on put back the 3.8 back and flash
it was the first thing i did checked for any boost leaks or air leaks yet still nothing
Checked that too found out that both raidiators were leaking fixed them yet no boost
they told me to bring the oem turbos to test them ito see if the problem from the turbos and still no boost
Thanks all for ur help if u have any more info on wht am dealing with feel free to jump in and post a comment
Old Sep 19, 2009 | 07:39 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Sounds like you need a competent shop to look things over, maybe someone could recommend a shop in your general area.
Old Sep 19, 2009 | 05:52 PM
Well there isnt much Germen cars specialists in my car all for muscle cars .. now my car is at the dealer testing it and stuff
Update : Maf sensor checked still no Boost
Old Sep 21, 2009 | 05:57 PM
vividracing's Avatar
Boost Leak test, then try a new MAF.
Hybrid
Jun 28, 2024 06:05 AM
Bmw M3 Guy
Feb 21, 2018 09:29 AM
COBB Tuning
Mar 29, 2016 09:26 PM
VGLNTE1
Aug 24, 2015 12:23 PM
