Durametric Data Logging
Old Sep 29, 2009 | 05:48 AM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
when data logging during driving, does the OBD II cable get on the way when engaging the clutch? should i drive the car normally or go WOT/ and for how long?
Old Sep 29, 2009 | 07:30 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
for tuning purpose start the dataloging and then go from 2000 rpm to WOT then back down again then hit stop on the datalog save the file, turn off the Durrametric and restart it to do another run.
Old Sep 29, 2009 | 08:33 AM
Prche951's Avatar
or you can start it, and run it the entire time you are driving without stopping it. Then you export the file to excel, and cut it down to the runs only, that way it is all on one file. That is how I do it. I keep the parameters to about 8-10 and I get about 2.5-3 samples per second. I have heard that with a well optimized laptop, you can get up to 5 samples per second.
Old Sep 29, 2009 | 08:57 AM
jalmood's Avatar
yes it is for tunning purpose, but Isn't one run enough if i go WOT on second and third and maybe half through fourth?
Old Sep 29, 2009 | 09:07 AM
Prche951's Avatar
the higher the gear you do WOT, the better. More load. I would do short shift in 2,3 and wot through 4th.
Old Sep 29, 2009 | 12:30 PM
jalmood's Avatar
For tunning purposes what info do i need to tick on other than AFR?
Old Sep 29, 2009 | 01:06 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
I have done durametric logs in 2 ways,
1. starting in 2nd at 2000rpm then WOT, shift and the same through 4th. This wont give as much load information as prche951 mentioned.
2. My tuner prefers this method.....start at 2000rpm in 4th and WOT to redline. I usually coast a mile or so to cool the IC's, I don't advise in immediately stopping after a WOT run as this can heat soak your IC' and turbos after a bunch of runs.
I usually do 4-6 runs, this will give the tuner a very good idea what is going on.
I also have had better results with having power connected to the laptop when datalogging, I'd imagine it gives more samples per second, Im sure this can be manually configured as well.
Off the top of my head you will need both lambdas, injector duty cycle, IAT, boost pressure and ????....I'll edit this when I get home tonight.
Old Sep 29, 2009 | 01:49 PM
jhuang25's Avatar
jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !
This is what I've been told to log...hope it helps.
1500 to redline.
3rd or 4th gear
Log
Engine speed (rpm)
Engine load
Ignition angle
Oxygen sensing bank 1
Adaption range 1
Adaption range 2
Oxygen sensing bank 1 actual lambda value
Actual boost
Old Sep 29, 2009 | 01:50 PM
jalmood's Avatar
Thanks, i will be waiting for the additional info.
matt2ace
Nov 23, 2019 11:38 AM
White991TT
Mar 8, 2016 06:01 AM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
