Where to find instructions for installing CF
Old Sep 23, 2003 | 09:11 PM
GT2wannab's Avatar
GT2wannab is infamous around these parts
I am getting CF door handles, bins, and vents next week. Where can I find DIY instructions to install these
Old Sep 23, 2003 | 09:38 PM
msindi's Avatar
I can walk you thorugh them...the door handles are EASY!! I did the alu on mine!!
Old Sep 23, 2003 | 10:09 PM
GT2wannab's Avatar
Thanks bud, I will call you when they get here.
Regards
Old Sep 24, 2003 | 06:44 AM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
Loren at Renntech.org.... the DIY pages have detailed instructions for some and Loren will email the rest if necessary. I changed out the rear console, upper console, batwing, vents, defroster covers, door handles and bin covers all from his instructions... The hardest is the defroster covers... Rest was pretty easy...
Old Sep 24, 2003 | 06:50 AM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
Make sure you get yourself some decent Torx screwdrivers and a good straight edge such as small puddy knife. For the door covers, you need a tiny torx driver because many of the screws are difficult to access.
Old Sep 24, 2003 | 07:09 AM
Gary (Fl)'s Avatar
Eric, is correct. I went and bought a small wrench that has a typical box wrench at on end and the other was like a ratchet. Added the adapter and the correct torx bit. The total depth was about 1.5 inches which made it easy to access, tighten and remove all the screws for the bin covers.
If you not concerned about saving the door handles they are easy to remove. It is easy to break off one or two of the clips if you are not careful on the old handles. No big deal if your going to chuck them anyway.
Good luck...
Old Sep 24, 2003 | 07:17 AM
GT2wannab's Avatar
Thanks guys for the help!!!
Old Sep 24, 2003 | 07:45 AM
Joe West's Avatar
Joe West is infamous around these parts
Can you provide a link?
Joe West
Old Sep 24, 2003 | 08:11 AM
Gary (Fl)'s Avatar
Joe West
Renntech
Go to the DIY pages under forums. If you don't see what you need just email or PM Loren. He has always been very helpful..
Old Sep 24, 2003 | 01:13 PM
seh1's Avatar
seh1 is infamous around these parts
Bin Covers
For the bin covers you can also remove them entirely before messing with a couple of the hard-to-reach torx'. Just use a needle-nose to pull the front pin out (you may have to work it some but its only held by friction) and then move the bin downwards and forward to pop the rear pin out of its hole.
00aston
Sep 16, 2022 09:19 AM
su_maverick
Aug 21, 2015 07:14 PM
