6 Pot Brake conversion, Help!!!
Old Oct 23, 2009 | 12:45 AM
GTRETA's Avatar
GTRETA is a splendid one to beholdGTRETA is a splendid one to beholdGTRETA is a splendid one to beholdGTRETA is a splendid one to beholdGTRETA is a splendid one to beholdGTRETA is a splendid one to beholdGTRETA is a splendid one to behold
I have an opportunity to swap my brakes (Stock 996 Turbo) to Stock 997 Turbo brakes from a smashed car, they are 6 pistons calipers etc, questions is, are these a direct bolt on?
TIA for any help!
Old Oct 23, 2009 | 07:33 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Should be. I installed those 997 turbo brakes into a 996 C2 with GT2 front wheel carriers. I needed 1,5mm shims between disc and hub to center disc properly to caliper.
EDIT: 997 turbo discs--> 996 turbo wheel carriers, no shims needed. 997 ( or 996 ) turbo discs ---> 996 GT2/3 wheel carriers, shims needed.
Old Oct 23, 2009 | 01:14 PM
Mikelly's Avatar
Rotor is a direct swap and caliper should be perfect!!
Mike
Old Oct 23, 2009 | 01:36 PM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
You don't need any shims.. just straight bolt on between a 996 turbo and a 997 turbo.
Make sure you get some GT3 air ducts.. it's cheap
Old Oct 24, 2009 | 11:20 AM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
Just run the fronts from the 997 and keep your 996 rears. I was told the brake bias would be off if you run the rears from the 997 turbo. They will bolt on but have too much rear bias for our 996 cars. I have a set of like new 997 turbo rear discs and rotors if anyone wants them. I hear you can use them if you are running larger brembo 8 pot fronts. I am running 997 turbo fronts with 996 rears.
Old Oct 24, 2009 | 05:58 PM
GTRETA's Avatar
Awesome, thanks guys for all your help, getting it done tomorrow, will get some pics!
ModBargains
Ferrari Vendor Classifieds
Oct 13, 2015 03:47 PM
ModBargains
Lamborghini Vendor Classifieds
oo7
Sep 10, 2015 08:08 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
