5th MAF is blown...
Old Nov 16, 2009 | 02:39 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
I am on my 3rd MAF this season... is there a solution?... I am on Proto Tune, can I easily just replace MAF and get Todd to adjust program accordingly?
Old Nov 16, 2009 | 08:53 AM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Skandalis you have PM.
Old Nov 16, 2009 | 01:05 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Affirmatory
Old Nov 16, 2009 | 01:31 PM
art4iza's Avatar
Yep, all you need is the proto Y pipe with the Ford MAF, hook it up, get Todd' tune and bammmm....there you have it. I had my share of blown MAF's in the good old days
Old Nov 17, 2009 | 10:27 AM
Zippy's Avatar
Yes. 480 Crank HP!
Old Nov 17, 2009 | 11:00 AM
Originally Posted by Zippy
Yes. 480 Crank HP!
Old Nov 17, 2009 | 01:37 PM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
The GIAC Hitachi MAF/software conversion is the way to go. Durable hardware and reputable software.
Old Nov 17, 2009 | 03:03 PM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
Do you have an oiled type Air Filter that will do it.
Old Nov 17, 2009 | 03:22 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Originally Posted by cjv
The stock MAF is not really any good for much above 600 hp of air flow.
And for just below 600 (at the crank) is there any better alternative than OE Bosch (P#996.606.124.00) with out re-tune.....if you are not near Todd, or any tuner.
TIA
Old Nov 17, 2009 | 03:31 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
The tuners do it remotly also through a local shop
Old Nov 21, 2009 | 01:15 PM
911TurboRules's Avatar
911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of
Sorry about this dumb question but how do you know when your MAF is blown?
Thanks,
Paul
Old Nov 21, 2009 | 01:26 PM
wross996TT's Avatar
Thanks,
Paul
Measure voltage at pin III/23 and ground, switch on ignition it should read .9-1.1V. Then start the engine and it should read ~1.4V or you will need the Durametric software, a PST2 or PIWIS tester to read the air flow over the MAF at idle and at 2500 RPM.
Typically you will get ABS/PSM lights as well...
Old Nov 21, 2009 | 02:52 PM
Thanks. I'll give it a try. I've been getting the ABS/PSM lights intermittently.
Paul
Old Nov 21, 2009 | 03:32 PM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Todd has it, Hitachi one. I just ordered one for my blown oe maf. My oe Maf worked fine in EVOM intake for 2 mos. After put in Tial A28, maf was blown in 2 minute driving. It was on only minimum boost also, .2-.3 bar. Still think it was crazy to blow maf at very light load of A28. Why it did not blow maf at full load of stock turbo?
Old Nov 21, 2009 | 04:10 PM
When did you order one from Todd?
