Removed Cats.....Nice improvement..
Old Nov 19, 2009 | 09:04 PM
CAA's Avatar
CAA
CAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to all
I had my cats removed and had a customized straight pipe installed with a flange for quick removal if needed for smog checks...To my surprise, the check engine light remained off...I had a previous FVD flash so that was a shocker.
The car does act different..Off the line, there is a small lag but once it gets moving i shoot up to .9 immediatly. I am spooling quicker. At idle, its just as quiet as stock, but when you hit it, it sounds pretty good. Im running a speedtech exhaust and cant be happier with the setup. This beta test was well worth it...Garrett turbos are on the way in Jan........
CAA
Old Nov 19, 2009 | 10:54 PM
cjv's Avatar
cjv
Moderator
CAA
Being from California I would not advertise this. Hugh fine if discovered.
Old Nov 19, 2009 | 11:22 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
It does make a difference, yes. Listen to Chad's advise here and have fun.
Old Nov 19, 2009 | 11:32 PM
legendr34's Avatar
legendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud of
In California, as far as I know, it is a fix it ticket
Old Nov 20, 2009 | 12:09 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
It is a fix it ticket until you fail to pass smog test. Then it's put all the stock stuff back on to get you're new tags.
Old Nov 20, 2009 | 01:09 AM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Way to fix it. Swap the cat in and out when you need to.
Old Nov 20, 2009 | 01:38 AM
soslo's Avatar
soslo is infamous around these parts
does it smell?
Old Nov 20, 2009 | 05:19 AM
Prche951's Avatar
get a set of 100-200 cel cats and you will be that much closer to straight pipe and be legal.
Old Nov 20, 2009 | 08:31 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
CAA
Do straight pipes dron ???.I have Fabspeed and 100 cel cat and it drons from 2,300-2,800 rpm.
Old Nov 20, 2009 | 09:20 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Does the Pope s#it?
Old Nov 20, 2009 | 09:23 AM
ttboost's Avatar
Originally Posted by TXGold
Does the Pope s#it?
No. I think he has people do that for him...
Old Nov 20, 2009 | 09:41 AM
rdss's Avatar
Does the Pope s#it?
Thanks TX now i have my question clear out
Old Nov 20, 2009 | 04:55 PM
cjv's Avatar
cjv
Moderator
California Highway Patro and Patrol Units in the Sheriff's department now carry infrared scanners that can detect law-breaking levels of exhaust. They wont pull you over, but you may get a $500 fix-it ticket in the mail.
I believe SMOG Checks for performance vehicles are now controlled by the Sheriff's Department. Your vehicle is required to pass the three following tests:
1. Visual Inspection of the Exhaust system and engine bay.
2. OBD2 Unit and Sensor Check
3. The Sniffer (A prod placed in the exhaust to measure levels of emissions.)
4. The optional fourth is a decibel check for systems that are "too loud."
Failure to meet any or a combination of the required parameters above can result from a warning, a no-cost fix it ticket, fix-it ticket and fine that can reach $2,500 or impounding.
Old Nov 20, 2009 | 05:09 PM
CAA's Avatar
CAA
Thats why it is flanged with an easy bolt on bolt off application......All good!!!!
Old Nov 20, 2009 | 05:45 PM
Prche951's Avatar
hail mary
Drone with fabspeed straight pipes is unavoidable and it is between 2300 and 2800 rpm.
