Wheel Spacers and Lug Bolts.
Old Nov 24, 2009 | 12:24 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
Question Wheel Spacers and Lug Bolts.
I have an 03 Turbo. The 1st thing I am looking to do is move my rear tires and wheels out 3/4 of an inch so they line up at the edge of the fender flairs. I found some 21mm spacers but I can't find lug bolts. Does any one know of a company that I can purchase long enough lug bolts for these spacers to work or do I need to go another route to get my wheels and tires pushed out that far. Any advice will be appreciated.
Old Nov 24, 2009 | 01:21 PM
Divexxtreme's Avatar
Give www.automotion.com a call. 1.888.787.3626
Old Nov 24, 2009 | 01:49 PM
SweeeTT's Avatar
SweeeTT is infamous around these parts
Also try Damon at Tire Rack. I got them from him - excellent service!
Old Nov 24, 2009 | 03:05 PM
Turbo Fanatic's Avatar
http://www.automotion.com/product.as...dept%5Fid=5128
you need 45m stock + 21mm spacer width = 67mm (68mm is close enough) wheel bolts
you will need to roll the rear fenders to fit that spacer
Old Nov 24, 2009 | 03:39 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
21mm is alot......if you are running OE twists......might want to see pics of that.
....and, some will have opin to use stud bolt on spacers when you are 20+ or whatever....some not.....just my $.02
Good luck.
Old Nov 24, 2009 | 07:32 PM
Gregg
As the resident offset expert I'll defer to you. I can tell you this. I used 15mm spacers all around before rolling the fenders. Rolling the fenders easily opens up more than 10mm. I really think he'll be OK.
Let us know how it goes!
Old Nov 24, 2009 | 07:49 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
Originally Posted by ari
Gregg
Ari,
it does stick out does it not ? Hence i wanted to get rid of the 21 mm that we traded...i track my car at the road course often, that if i would have added the 21mm spacer it would have taken my rear qrt panel off !
Old Nov 24, 2009 | 08:02 PM
Honestly don't know since I haven't tried it yet.
These are the stock TT twist offsets
Front = 50mm
Rear = 45mm - 21mm = 24mm offset. Techart 11" rims come in 25mm offset stock. I think it will fit perfectly under the fenders if you roll them.
Old Nov 24, 2009 | 08:13 PM
I ran 21mm RUF spacers on my 996TT for a very long time. I had to in order to keep my BBS wheels from rubbing my aftermarket I/C piping.
Anyway, I rolled the fenders before install, and never had rubbing issues after they were on.
Here's before and after shots:
Old Nov 24, 2009 | 08:22 PM
this is what happens....so i do not want 'flush' just fit 335's without rubbing inside and outside...
Old Nov 24, 2009 | 09:59 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
15mm spacer in the rear on stock wheels
Now
Old Nov 24, 2009 | 10:01 PM
Nobody said anything about 335s I'm talking about 295... Remember STOCK wheels and tires
Links, have you rolled yoru fenders? I think you have another 7mm in there :0
That said, I'm running 15mm spacers on my 11.5" Champions running 315/25-19s with zero rubbing and without any aggresive rear camber. Trying to make the rears last as long as possible. I'm spinning them everyday when I squeeze the throttle as is
Old Nov 25, 2009 | 06:45 AM
GreggT's Avatar
LiNks pics are helpful......I usually trust pics before my math.....and ari is right, what rubber does matter (sometimes even between needing fender prep and not).
I know these pics have been up many times.....old and car has changed but.....this is 14mm all around with 225 and 295 Sport Cups.
Suspension and neg camber are the last variables......dropped in this case does require fender prep.....for whatever that's worth.
Old Nov 25, 2009 | 07:08 AM
boss351's Avatar
boss351 is just really niceboss351 is just really niceboss351 is just really niceboss351 is just really nice
What have you been running 335's on (wheel width)?
I have been wanting to try 315 30 18 Nitto NT01's on my OEM twists for the track but have been worried about rubbing (inside) and what the extra rubber width would be like on those rims. So far I have used OEM size Toyo R888 and Yoko A048's, I have some MPSC's going on next to see how they compare.
Old Nov 25, 2009 | 07:10 AM
boss351's Avatar
Another source for spacers and lug bolts:
http://www.radusadirect.com/
