is this normal ? please help
Old Nov 30, 2009 | 02:47 PM
mitcho168's Avatar
mitcho168 is infamous around these parts
sometimes my temperture thing says 180 when its normal then i notice when i drive longer or drive it hard a bit it goes up to 190 is this normal? please help
Old Nov 30, 2009 | 03:13 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
Mine usually stays around the "0" of the 180. When is the last time that you took a vacuum to the front grills and cleaned all the debris away from the radiators?
Old Nov 30, 2009 | 03:58 PM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
190 is within acceptable range as per factory specs however if it should start to rise at any time above that point, you should pay close attention.
It's possible also that there was some coolant service done in the recent history where not all of the air was purged from the system. Air in the system will result in slightly higher cyl head/coolant temps.
Old Nov 30, 2009 | 04:16 PM
wross996TT's Avatar
Once warmed up, mine never moves from between the 8 & 0 in 180...regardless of conditions or driving
Old Nov 30, 2009 | 05:13 PM
mitcho168's Avatar
alright thanks guys i should check it out.
Old Nov 30, 2009 | 05:15 PM
mitcho168's Avatar
is there anything specific i should check?
Old Nov 30, 2009 | 09:36 PM
landjet's Avatar
Mine always reads 180 on the street, but on track it goes up to 190 or so.
Old Dec 6, 2009 | 06:21 PM
U74sry's Avatar
U74sry is infamous around these parts
always 180
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Highlander
Dec 21, 2015 08:42 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
fanporsche
Sep 30, 2015 02:26 PM
