View Poll Results: What should I do?
Turbo Upgrade (K24/18g)
17
26.56%
GT2 front and GT2 deck lid with HUGE wing
7.81%
Suspension Upgrade such as JIC coilovers
29
45.31%
Give the money to the poor... :-)
20.31%
Voters: 64. You may not vote on this poll
Decisions, Decisions - Help me!
Old Dec 29, 2009 | 08:32 AM
  #31
tvr-4's Avatar
tvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond repute
Originally Posted by raineycd
Thanks Jon! OK I am trying to put a list of parts together and here is what I have so far:
Set of Coilovers
Front and Rear Sway Bars
Front and Rear End Link Sets
GT3 Front Lower Control Arms and Shims
Rear Upper Dogbones
Rear Toe Links
Am I missing anything?
Thanks again guys!!!
Chad,
You are welcome to drive my car any time to see how you like the street feel of the JIC. I don't have any other pieces on my car, but that should not matter for the street.
Good luck, your car is shaping up into a great setup!
TK
Old Dec 29, 2009 | 08:42 AM
  #32
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Set of Coilovers
Rear Upper Dogbones
Rear Toe Links
Adjustable thrust arm bushing for the caster adjustment
Old Dec 29, 2009 | 10:37 AM
  #33
landjet's Avatar
Rear camber locking plates{cheap} keep your rear alignment from changing. Without these I have read where some guys have had their alignment change while at the track and ruined their weekend.
JIC's offer various spring rates so they are a pretty good choice. KW does also and they are supposed to be highly thought of in Europe. If I were you, I'd call a racing shop like GMG, ask for Fabryce and talk to him about the variables. He can set you straight as far as spring rates and alignment settings. Jon has his car well sorted for the tires he uses. I tried other tires and had to change my settings after eating up the rears. Since alignment is tire specific, you may want to think about that ahead of time. Street tires and track tires will have different settings. And before I forget, R compound track tires make a huge difference in track performance. I have followed professional racing all my life and had always heard that tires really make the car handle, but never really understood that until I got my first set of sticky tires and felt it for myself.
Old Dec 29, 2009 | 12:08 PM
  #34
FAST FWD's Avatar
Agree again with Larry. I use Michelin PSC's on the track. My car eats Hoosiers in a couple of days.
Also correct about street vs. track alignment. I go back to the stock alignment specs for the street, where I use Kumhos. Nice thing about the setup we've described is that it isn't too hard to go back and forth. I use Longacre toe plates and Smartcamber tool for camber to check, but for the most part, I just count turns on the adjustments to go between the two setups.
Old Dec 29, 2009 | 11:03 PM
  #35
raineycd's Avatar
OK I have leads on all the suspension parts except for Rear Camber Locking Plates. Any ideas where I could get those?
Old Dec 30, 2009 | 12:24 AM
  #36
heavychevy's Avatar
I wonder why some people can't get more camber with their JIC's...... I've seen LOTS of 996's with JIC easily well over 2*.
Personally I think spending 10k on suspension is overkill unless you're going to track it extensively.
Old Dec 30, 2009 | 06:57 AM
  #37
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
everyone needs more hp....lol
Old Dec 30, 2009 | 09:01 AM
  #38
landjet's Avatar
RSS is where I bought them. They go by Stuttgart performance on the web. They are a site sponsor here.
Old Dec 30, 2009 | 11:16 AM
  #39
FAST FWD's Avatar
I'm pretty sure it's because of the AWD. Different uprights change the suspension geometry.
I'm all for overkill when I'm spending somebody else's money!
Old Dec 30, 2009 | 11:21 AM
  #40
raineycd's Avatar
LOL my wife about freaked when I added everything up. Not including installation, which I will probably do most of myself...
So will probably start with some coilovers and sways and go from there... That will probably get me 90% of where I need to be anyway... I ain't that skilled to need the other 10% yet!
Old Dec 30, 2009 | 11:26 AM
  #41
FAST FWD's Avatar
Well, you might try sway bars and a set of rims and track tires. Then you can explain to her that you need to do all of those other mods to make the track tires last longer.
Old Dec 30, 2009 | 11:39 AM
  #42
raineycd's Avatar
But then that adds a whole new can of worms. How to get the track tires to the track...
My poor little van does not have the capacity to tow the heavy p-car...
Old Dec 30, 2009 | 11:46 AM
  #43
Merlin's Avatar
Merlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of light
Funny thing you have going on there with the wife. I am in the same negotiations after our 3rd kid was born 2 1/2 months ago
I am currently on a black ops project to get my K24/18gs installed, but I am trying to get my KWv3's with a 'SNIP SNIP' deal. Hope mine works out like yours is.
Oh yeah, My vote is for suspension 1st.
Good Luck
Old Dec 30, 2009 | 12:50 PM
  #44
heavychevy's Avatar
All but one of them are AWD, including mine. I had 2.8 on the front of mine, so did Al Norton. Manalex had well into the 2's as well. All turbo's. There was another member who sold his Turbo, he had it way up there too. The rear's were over 2* as well. The only mods were JIC with included camber plates.
Porsche tolerances are pretty tight, I can't see how you could get that on so many in one place, and intermittently anywhere else.
Old Dec 30, 2009 | 01:48 PM
  #45
landjet's Avatar
This is an excellent start. Make sure you talk to someone knowledgeably about the spring set, not just some vendor who sells parts. You'll thank me later. GMG, Viper Bob, someone like these guys.
