View Poll Results: What should I do?
Turbo Upgrade (K24/18g)
17
26.56%
GT2 front and GT2 deck lid with HUGE wing
7.81%
Suspension Upgrade such as JIC coilovers
29
45.31%
Give the money to the poor... :-)
20.31%
Voters: 64. You may not vote on this poll
Decisions, Decisions - Help me!
Old Dec 30, 2009 | 03:44 PM
  #46
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Originally Posted by heavychevy
All but one of them are AWD, including mine. I had 2.8 on the front of mine, so did Al Norton. Manalex had well into the 2's as well. All turbo's. There was another member who sold his Turbo, he had it way up there too. The rear's were over 2* as well. The only mods were JIC with included camber plates.
It must be that there is a difference between the diameters of the JIC and PSS9's then. Larry and I have PSS9's, and we couldn't do it. Maybe that will help influence Chad's decision. It sure would make the setup easier if it could all be done from the top.
Jon
Old Dec 30, 2009 | 03:53 PM
  #47
ttboost's Avatar
Originally Posted by raineycd
But then that adds a whole new can of worms. How to get the track tires to the track...
My poor little van does not have the capacity to tow the heavy p-car...
Read this Chad...
https://www.6speedonline.com/forums/...-porsches.html
Old Dec 30, 2009 | 04:15 PM
  #48
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
Chad, Didn't read all the posts, but ya gotta put the money into the suspension. JIC's or PSS9's would be a good place to start and you might consider calling some tuner shops to see if you can find a set from someone upgrading to Moton's. You could save some $ that way. Also, it's nice to experience and learn from each incremental mod, but you MUST consider sway bars at the same time or shortly after you get the suspension upgraded. Also, during this process will be the time for a new allignment and camber options (maybe to GT2 spec).
Old Dec 30, 2009 | 04:38 PM
  #49
raineycd's Avatar
Originally Posted by ttboost
Thanks Mike, don't know if I can do that! It just isn't right!
Hey David! Yep, will probably start with coilovers and sway bars. Then probably track tires after that. That will probably be the most bang for my buck. There are some JIC's that come up on the for sale section every once in a while. I will keep my eyes peeled...
Jon
I am leaning toward JIC's from the feedback I have seen and that they come with all the plates / pillowballs, etc.
Old Dec 30, 2009 | 05:19 PM
  #50
raineycd's Avatar
Originally Posted by landjet
This is an excellent start. Make sure you talk to someone knowledgeably about the spring set, not just some vendor who sells parts. You'll thank me later. GMG, Viper Bob, someone like these guys.
What springs are you running? Are softer (lower number) better for track or harder (higher number)? What problems did you run into?
Old Dec 30, 2009 | 05:49 PM
  #51
Mikelly's Avatar
Lot of "fast" cars on this site that will never be driven to their potentially on the street or the track... You have demonstraited that you're interested in driving on roadcourses. You should really think about that when moving forward with mods. Suspension, brakes, and more seat time. That's what you "should" do. Adding power to the mix (and especially certain turbo combos) will only complicate your attempts at learning.
Mike Kelly
Old Dec 30, 2009 | 05:55 PM
  #52
Mikelly's Avatar
I'd do the following suspension parts:
GT3 Lower control arms
Rear Dog bones (You can search on my thread elsewhere about these)
Sway bars with upgraded HEIM Joint style drop links
thrust bushings for the control arms
Rear Tie rod ends with lockplates
Your favorite coil over.
Budget for scales/balance and a good alignment.
Shop Smart and you should have less than $6K in everything installed.
Mike
Old Dec 30, 2009 | 05:58 PM
  #53
raineycd's Avatar
Mike
Thanks Mike! Was wondering when you would chime in!
Old Dec 30, 2009 | 06:45 PM
  #54
Mikelly's Avatar
'Eh, Worked a 12 hour day today... Not been online much this month...
Mike
Old Dec 30, 2009 | 08:09 PM
  #55
raineycd's Avatar
Mike
Beats the alternative I hear... You sticking with the PSS9's?
sdg1871
Nov 22, 2015 07:27 PM
007 Vantage
Oct 8, 2015 08:35 PM
