Unknown Flash - Need to Data Log
Old Jan 2, 2010 | 03:23 PM
BlueRanger's Avatar
BlueRanger is infamous around these parts
I purchased my car (non x50) with a (1.0 bar) flash that the previous owner could not give me any information on.
I would like to data log to make sure it is running safely.
Can anyone recommend which actual values I should data log with the Durametric to make sure this mystery flash is running safe?
Thanks!
Old Jan 2, 2010 | 04:08 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
You should log Air fuel (lambda) from the 2 banks and at full throttle it should be between 11.5-12.5
The durametric will log in lambda,just multiply this with 14.7 and you'll have the correct air fuel ratio.
Old Jan 2, 2010 | 06:12 PM
BlueRanger's Avatar
From the Actual Values List would these be:
Lambda setpoint B1
Lambda setpoint B2
or
Oxygen sensing, bank 1 Lambda Value
Oxygen sensing, bank 2 Lambda Value
Thanks.
Old Jan 2, 2010 | 06:14 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
would also look at timing, load and IDC.
Old Jan 3, 2010 | 01:57 AM
dixie's Avatar
Lambda setpoint B1
Lambda setpoint B2
or
Thanks.
Oxygen sensing, bank 2 Lambda Value..
Do a run in 4th or 5th gear from 2000 rpm till redline..
When you made the run push export button and save the file,now you can see data in excel...
Old Jan 3, 2010 | 02:58 PM
BlueRanger's Avatar
I appreciate your response .
Old Jan 3, 2010 | 02:59 PM
BlueRanger's Avatar
What is IDC?
Old Jan 3, 2010 | 03:23 PM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
What is IDC?
Injector Duty Cycle.
You may also want to crack open your ecu case to see if the main 44 pin psop chip has been soldered on before (see pic).
Many european tuners solder in a encryption board with their logo. If its been soldered and there is no board, its most likely upsolute.
Old Jan 3, 2010 | 03:49 PM
BlueRanger's Avatar
Thanks Tony I will check it out.
If it turns out not running safe can my car be re-flashed with a safer tune?
Also which Actual Values combination do you recommend I run?
Thanks!
Old Jan 3, 2010 | 07:43 PM
trident111's Avatar
trident111 is infamous around these parts
Great info, I have a similar situation on my Turbo S, I think I have an FVD flash but am not 100% sure.
Old Jan 3, 2010 | 07:57 PM
smithk3933's Avatar
smithk3933 has a spectacular aura aboutsmithk3933 has a spectacular aura about
I believe that with FVD, they keep track of the VIN of the cars that have their flash. I think that Rhonda@fvd on this site can check that information.
Old Jan 3, 2010 | 08:02 PM
unvmy996's Avatar
parameters i log when i need my tuner to check are
oxygen sensing bank 1 and 1 lamda
ignition angle
engine load
rpm
boost actual sensor
00aston
Aug 5, 2023 10:59 PM
wrs
Nov 17, 2016 06:53 AM
COBB Tuning
Nov 3, 2015 08:39 AM
Oct 6, 2015 06:13 PM
Oct 2, 2015 02:23 PM
