How to tell K16 from K24 outwardly
Looking at a potential purchase and there is some confusion if the car has had the K16 turbo's replaced with K24's. Is there an easy way to tell from the outside that I could have the current owner verify?
Thanks.
Thanks.
The id tag on the turbos has the relevent numbers. Small tag -usually yellow or blue. It is riveted on-- quite small -prbably need a wipe to read.
Take no notice of the cast in numbers in the housing itself as the start with K24 in both K24 and K16 versions.
seen yellow tags with k24s... anyone confirm?
2001 996TT 3.6L and stock ECU
K24's have yellow AND blue tags-- I have both in my posession now.Stock standard from the factory with both colours.
1) Take car for test drive
2) Drive straight to drag strip
3) Do three runs and several highway pulls
4) Take to dyno for verification
5) Return to owner
6) Post results here
7) We'll let you know........But you would have had fun either way.
5) Return to owner
My K24s have yellow tags
I have asked about this before and it seems there is no answer (so far) as to why some tags are blue and some are yellow
If you check the small coloured tag which is riveted to the turbo housing you will see some part numbers on the tag which will help you to identify them
Numbers for the K24s are as follows
OEM Part numbers
99612398371
99612398471
KKK Part numbers
53249707005
53249707006
Note - you will have both the OEM and KKK part numbers on each turbo charger
OEM Part numbers
99612398371
99612398471
KKK Part numbers
53249707005
53249707006
Mine have blue tags and they were new in the box K24's prior to modification to 24/18G. They were not from the Porsche factory, but from BW.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
I got all excited when the thought was a blue tag = K24s. The numbers on my blue tag are 99612301475
DF50299440081
53169706727
From the other numbers posted I am assuming a k16 turbo with a blue tag.
DF50299440081
53169706727
