Anyone have a good way to remove the stock wing without the special tool?
Old Jan 16, 2010 | 01:13 PM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
Old Jan 16, 2010 | 02:23 PM
jpflip's Avatar
Many people use strap wrench. Mention here: https://www.6speedonline.com/forums/...-bay-area.html
Old Jan 16, 2010 | 05:41 PM
2LOW4's Avatar
2LOW4 is infamous around these parts
Ditto! I just stuck a 1/4" drift in the hole to grab the aluminum "button" and then used a strap wrench on the cylinder.
Old Jan 16, 2010 | 09:51 PM
LamboTT's Avatar
1/4 drift, what is that? Is that basically just a pin? Have to get a small strap wrench I suppose.
Old Jan 17, 2010 | 12:52 PM
2LOW4's Avatar
Drift punch. It's the same diameter to the tip with no point. Pin or rod should work fine. I used an oil filter strap wrench I had, it adjusted down small enough.
Good Luck
D_Nyholm's Avatar
D_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant future
Not sure what a drift is, but I used a countersink in mine and it worked. I bet a finish nail would work as well
Old Jan 17, 2010 | 03:04 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
took mine to neillo porsche the removed my wing in the parking lot, took 5min no charge of course i will buy my next car from them
Old Jan 17, 2010 | 08:46 PM
LamboTT's Avatar
I got it off with rubber strap wrench and a little screw driver. Now that I know how it works, I could do it in minutes but it took a little to it figure out
Weebs
Nov 29, 2018 08:20 AM
Weebs
Aug 21, 2015 06:35 PM
Vrseis
Aug 20, 2015 07:41 AM
Aug 19, 2015 06:55 PM
