Sachs Stage 3 & LWFW "Rattle noise"
Just drove a Proto car yesterday with a LWFW and Sachs stage 3 . The car shifted smooth and clutch pedal felt as good as stock. Engagement point is mid pedal and very snmooth.
My question is when in neutral and motor idling, there is a slight rattle noise coming from the rear. As soon as you push the clutch in, no more rattle noise. This is with the car still in neutral.
The owner said this is " Normal for this setup". never heard this on any other p-cars I have driven.
What do you guys think.
We think you just drove your first car with a light weight flywheel. Any car that had a factory dual mass flywheel, that is REPLACED by a NON dual mass flywheel will make this noise. It is a normal noise for a car with a LWFW.
The other potential sound you may find is a slight rattle during WOT in a higher gear at lower RPM loads. Both idle noise and WOT rattle go hand and hand with many LWFW combinations.
TT Boost, yes it was my first drive with a LWFW. Everything else on the car was perfect and it just strck me as odd the noise it was making when it engaged and shifted otherwise perfect. Could you explain to me why the difference in flywheels would make this noise.
Is it not having the heavier mass of the stock flywheel causing the motor harmonics at idle to vibrate the throwout bearing slightly?
Something I just found...don't change your tranny fluid to decrease the noice....
http://www.uucmotorwerks.com/flywheel/gear_rattle.htm
Jeff
Jeff
research LWFW plenty of posts but the dual mass flywheel dampens the sound of the engine and transmission rattling around i have a LWFW at first i hated it now i just enjoy it as its music to my ears
Jeff
Jeff
100% true.
