TechArt 530HP vs EvoMs Stage4 X-50 package?
Old Feb 6, 2010 | 05:54 PM
Twinturbozs's Avatar
Twinturbozs is infamous around these parts
Ive been lurking about for some time and was wondering if anybody had some input on these two packages.
1. Which will provide bigger gains?
2. Which would be more reliable or streetable?
3. Will either be smoggable?
TechArt - 996 Turbo and GT2 - Engine Performance
Turbo Power Kit T2 for 996 Turbo 530hp/540 ft-lb (Base 420 hp). Motronic reprogramming, high-flow air filter, K16 mod. Turbochargers, carbon air box cover, ABS brake cooling air deflectors and transmission cooling ducts, must have manual transmission
or
EvoMs Stage4 X-50
The Stage 4 system expands upon the Stage 3 system by adding K24 Headers. The K24 turbos will help to reduce EGT's (exhaust gas temperatures) and will aid in allowing the turbos to spool up quicker.
Includes:
-V-Flow Air Induction System
-EVOMSit Intelligent Tuning
-Billet Diverter Valves
-Stainless Sport Exhaust
-Bosch Spark Plugs
-EVOMS K24 Headers
thanks
Old Feb 6, 2010 | 06:58 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
This is an interesting question.
Old Feb 6, 2010 | 08:28 PM
Ryboy996GT700's Avatar
Ryboy996GT700 is infamous around these partsRyboy996GT700 is infamous around these parts
I'd comment but I'm biased
Old Feb 6, 2010 | 08:37 PM
If your in the States go with a tuner that actually can pick up the phone and or even custom tune...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 6, 2010 | 09:14 PM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
Sent you a PM.
I would not look towards K24's, the response is not as good as modded K16's, with the right setup.
Old Feb 6, 2010 | 10:14 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Id put my money on the EVO X50 car w/ K24s from 50 - 130+mph
Old Feb 6, 2010 | 11:22 PM
ard's Avatar
ard
You seem like you are shopping specs and packages... as Markski said, you should shop for a TUNER. Find the 'brains' behind a 'mod plan' and then 'package' will be defined by your needs and budget.
If you are in SF, Sharkwerks is local... Kevin at UMW is up in the northwest (no sales tax). There are others...so your homework.
A
PS There are NO CARB CERTIFIED ENGINE MODS for California. Many will 'pass' but only because the shops don't know any better. Don't change any engine hoses, don't change the air intakes. I choose a Europipe exhaust as it looks pretty stock...
Old Feb 6, 2010 | 11:48 PM
sharkster's Avatar
All I would suggest is a good tune, a good exhaust, some DV's (and good plugs) and you're set
Old Feb 7, 2010 | 02:48 AM
Turbo Fanatic's Avatar
Does you car have K16s or K24s?
Old Feb 7, 2010 | 04:41 AM
Actually im in the market for my first 996TT the 2 vehicles of interest happen to have these different packages.
Old Feb 7, 2010 | 12:24 PM
Porscheboi7000's Avatar
Porscheboi7000 is infamous around these parts
Ca anyone with these actually installed weigh-in, I'm interested in seeing more about this as well.
Old Feb 7, 2010 | 02:36 PM
X50DAN's Avatar
X50DAN is infamous around these parts
Lightbulb Evoms stage 4
I've had the "full monty" Evoms stage 4 on my car since April, 2006; about 24k miles ago ('car now has 44k miles). 'Owned car since new; 'came with X50 pkg.
Install done by an Evoms dealer, along with total suspension mods. Those who say "find a tuner/installer" are correct. Many horror stories when installer of these various pkgs/components doesn't have extensive expertise.
My car has been "bullet proof" since mods completed, including many track days; being driven on track @ 10/10ths by professional drivers, etc.
I consider this a tribute to the Evoms pkg; but also the skill of installing shop (who also built my Dinan S/C'd S3 E39 M5; which has also been "bullet proof" for 3+ years and 34k miles).
IMO, regardless of pkg "name", who did installation is critical to consistent performance. Find out who did installation on each car you're looking at, then call pkg mfr to get their opinion of that shop.
BTW, I live in Calif. and have had no problems with smog compliance; w/o changing anything before testing. IMO, 'vast majority of smog stations have no idea what they're looking at; 'car easily passes "sniff" tests.
Good luck........
NC 996TT
Mar 23, 2023 06:19 AM
Fieldsport
Dec 2, 2015 06:31 PM
irish100p
Oct 24, 2015 09:37 AM
socalbreeze
Sep 11, 2015 12:37 AM
Gunther
Sep 10, 2015 10:30 AM
