gt2/gt3 brake kit upgrade
Old Feb 18, 2010 | 07:15 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
I know theirs a thread already made by Mike Kelly, where he
contributed a lot on from myths and thruth.
I'm currenctly upgrading my brakes on my 996 TT
Al and Mike both told me how to make 350mm rear rotors to
fit with fabricating this bracket. It's made out of Alum T6061 T6
I'll be doing a test fit this weekend.
Anyways, here is the bracket. Test fitting this Friday night !
Thanks to Al and Mike!
Last edited by GT3 Chuck; Feb 18, 2010 at 07:19 PM. Reason: registered users may not do group buys
Old Feb 18, 2010 | 07:22 PM
weoco's Avatar
weoco is infamous around these parts
I'm interested to know the results as well... please let us know.
Old Feb 18, 2010 | 08:30 PM
landjet's Avatar
If you buy 997TT rotors you don't need the bracket, they bolt right up.
Old Feb 18, 2010 | 08:31 PM
heavychevy's Avatar
I think in the rear you still need the bracket. Only the fronts bolt right up.
But I may be mistaken.
Old Feb 18, 2010 | 09:17 PM
ahardm3's Avatar
ahardm3 is infamous around these parts
Subscribed
Old Feb 18, 2010 | 09:41 PM
kennyjr748's Avatar
kennyjr748 is infamous around these parts
Heavy, you're right. You only need the bracket spacer in the back to mount the larger rear disc.
Old Feb 19, 2010 | 08:01 AM
landjet's Avatar
Not true. I have the stock 997TT 350mm rotors on my rears with no brackets since 2 years. You may need a bracket for rotors that are made by aftermarket manufacturers.
Old Feb 19, 2010 | 08:05 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
The Spacer is required when you use the original 996TT Caliper along with 997 Rotor... you can leave the Spacer out if using the 997TT Caliper along with the Rotor or there would be no spacer required if you had an original PCCB Caliper
Old Feb 19, 2010 | 08:06 AM
Well done that man!
Old Feb 20, 2010 | 01:44 AM
Here are pictures of hte fitment !!
Fits perfect. My rear rotors haven't arrived to test fit but the bracket
100% perfecto!
Old Feb 20, 2010 | 04:32 AM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Subscribed
Old Feb 20, 2010 | 05:35 AM
Well done Enrique... looking good
Old Feb 20, 2010 | 06:37 AM
landjet's Avatar
I guess I should have qualified my statement by saying I upgraded to the GT3 brake system all around, and with that, there was no need for any bracket.
Old Feb 28, 2010 | 12:13 AM
Hello people. Does anyone here know where I can find
Porsche yellow caliper paint thats exactly as Porsch'es PCCBs ?
Also intersting fact,
As I was reading the workshop manual, apparently the Turbo has bigger
surface pad area touching then the gt2 and gt3
Turbo:
Brake pad area front 314 cm2
rear 254 cm2
GT2
front 448 cm2
rear 248 cm2
Old Apr 28, 2010 | 06:13 PM
LO_996tt's Avatar
LO_996tt is infamous around these parts
PORSCHE yellow
Did you ever find a factory match of the yellow caliper color?
I just re-finished mine using VHT caliper yellow. I am not sure if they are a match. Mine appear to be a bit to "pastel" yellow. But I have not been able to see a factory yellow in person to verify---pictures are tough to judge color. I don't want them to be too "non-factory".
BTW--I did this years ago to my s2 cab and it was a pain to get them clean enough to paint while on the car. This time I went to Harbor Freight and bought a $79 soda blaster and got them completely clean and ready for paint (removed them first). Worked awesome. 1 hour extra paid off big.
Let me know if you find a brand that is a match..
