Just run 6,9 sec 60-130
Old Feb 21, 2010 | 11:46 PM
laurent965's Avatar
laurent965 is infamous around these parts
Hi guys
I just run from 100-200 km/h 6,9 sec. It is the first time for me, never did one before. 2 people on board , outside T° 8 celcius, standart fuel.
You guys are expert on run, is it a good time for my set up ? (see my signature)
Started on 3rd gear at 80km/h, should i do it differently ?
Thanks for the advise.
Old Feb 22, 2010 | 12:41 AM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
60-130 mph is different than 100-200 km/h.
Hmm, maybe try faster shifting, perhaps you should be able to do it bit better...
But I am no expert in straight line performance: I did 100-200 km/h in 7.0 seconds with similar test as you (although no passenger, measured with PBOX) and the car has 530 European pump fuel hp.
Old Feb 22, 2010 | 04:22 AM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
Well my setup is almost the same like yours,I have a 2001 with K16/24 but not zero clearance,5 bar FPR,blizzard intercoolers,carbon dual snorkel air box,light weight flywheel,BMC airfilter,europipe exhaust and FVD tune for 1 bar,545HP at the cranck and I did 100-200km/u in 6.8 seconds,did you ever put your car on the dyno because if you also are running at 1 bar I think your car won't have over 600HP.
Old Feb 22, 2010 | 04:24 AM
dixie's Avatar
Forgot to mention,I also start in 3th gear at 80km/u.
Old Feb 22, 2010 | 06:03 AM
MBailey's Avatar
A 6.9s 100-200 is approx 7.8x 60-130 which is not bad for your setup, imo.
Congrats! You should convert it to mph with the software and send to Scott for verification and addition to the list.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
BLKMGK
Sep 19, 2015 03:51 PM
Korntera
Sep 15, 2015 08:20 PM
captain Greg
Sep 6, 2015 04:14 AM
sleepy
Sep 4, 2015 11:59 AM
