How long should a water pump and coolant tank last?
Hi all.
How long do 996tt water pumps last in general, and also coolant tanks?
The shop that will be doing the fix for my coolant drop mentioned that
996tt water pumps and coolant tanks go fairly early on, suggesting I
do this work proactively. What do you guys think?
Joe
It really depends on the car and the enviorment its in.
I have done watertanks on 996 cars as early as two years into there life.
Waterpumps have failed on turbos as early as 15k miles
My personal GT2 needed a H20 pump @15k miles on it.
Its not uncommon for the parts to fail early.
OK. I was told the coolant pumps should last 100K..
but the coolant tanks on '01 and '02 are failing, and
they are cheap, so they should be changed.
I was told that water pumps are have a built in weep
hole when they start to fail they will weep coolant and
there is usually there is a crusty white area around the
pump.
Are water pump failures gradual usually, or can they
grenade? Should I just wait till I see that crust, or
should I just change the pump every 20,000 miles?
thanks Fabryce!
pump.
thanks Fabryce!
Mine failed around 36k. It's better insurance if you get it replaced. You don't wanna get stranded on the road.
http://www.youtube.com/watch?v=h0L0klF8lVo
This is good to know
http://www.youtube.com/watch?v=Um-h2...eature=related
pump.
pump.
think the coolant tank starts to turn brown as it hardens. suppose this can be used as a crude indicator of wear. pain to replace since minimum, engine needs to be lowered. Good to do if engine's out. if remember correctly cost on it is 125
Yup. As it starts to fade, turn brown and crack, it weeps through the small cracks.
Good to know, specially since I am thinking of making the jump to a 996TT.
nlakind
Nov 6, 2015 10:15 AM
turbotuner20v
Sep 11, 2015 12:02 PM
away
Sep 4, 2015 12:30 PM
LiquidElephant
Aug 27, 2015 06:17 PM
