New mods... EVOMS inlet pipes, GT2 slave conversion, Sachs "752" clutch/PP
Old Apr 11, 2010 | 01:35 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Originally Posted by Szpet
Is there any chance that you have the partsnumbers of all parts that are needed for the GT2 slave conversion?
Yes I do. PM me your email and I will send you a PDF of my order with Pelican.
Old Apr 11, 2010 | 03:38 PM
flash68's Avatar
I just realized I forgot to thanks my bro Kenny for letting me drive around on his stocker twists for a couple weeks while I figured out my IC piping clearance issue.
My bad Kenny, you're the best EVER!!!!
Old Apr 11, 2010 | 03:41 PM
ttboost's Avatar
Did you have clearance issues with the piping?
Old Apr 11, 2010 | 03:53 PM
flash68's Avatar
I did with the hard pipes I had fabbed from the IC to the turbos and from going to wider/taller wheels and tires. That's when I had S-Car-Go rearrange the pipes and change the angles and mod the IC outlet on on side, and then we played with spacers on the wheels to get as much room as possible. Ended up with 10mm spacers.
The inlet piping is perfect on one side (driver) but overshoots the turbo on the passenger side by about an inch or so so we are going to have it cut before the final bend and take a 1-2" section out and sleeve it to line it up properly. John D had to do the same thing on his car.
Old Apr 11, 2010 | 04:04 PM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
Pm me the parts list on the slave conversion also please.
Old Apr 11, 2010 | 04:09 PM
flash68's Avatar
It's a PDF so send me your email and I will send it back.
Old Apr 11, 2010 | 04:27 PM
ttboost's Avatar
Will this be an issue with stock size wheels?
Old Apr 11, 2010 | 04:34 PM
kennyjr748's Avatar
kennyjr748 is infamous around these parts
LOL...
Old Apr 11, 2010 | 04:38 PM
flash68's Avatar
Shouldn't be all. It had more to do with my hacked up Proto ICs that were made for GT35s more than anything. We have it rerouted now it works okay because I would have to spend quite a bit more in labor to get it perfect. I will do it later when I go for monster ICs down the road or something I guess.... it's okay for now. Not perfect but it works.
Even with my clearance tight, the stock twists on 225/295 tires were fine.
Originally Posted by kennyjr748
LOL...
Old Apr 11, 2010 | 05:22 PM
Blockhed's Avatar
Old Apr 11, 2010 | 05:36 PM
flash68's Avatar
Emailed you.
Old Apr 11, 2010 | 09:09 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
I have an evoms slave conversion bracket if anyone is interested....
Old Apr 11, 2010 | 09:27 PM
flash68's Avatar
Did you decide to not install it in yours?
Old Apr 11, 2010 | 09:38 PM
KPG's Avatar
KPG
I did install it and it worked just fine but I went with a Tilton triple clutch and it uses a push type slave and not the factory pull type.....
nlakind
Nov 6, 2015 10:15 AM
SharkyShark20
Sep 19, 2015 09:54 PM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
irish100p
Aug 31, 2015 01:04 PM
orbelo
Aug 30, 2015 12:26 PM
