Carrera GT test drive
Old Jan 14, 2005 | 05:15 PM
  #121
ColorChange's Avatar
ColorChange is infamous around these parts
Paul: The pressure on the 100mm spare is usually much higher and very different construction than the stock tires. It only works with the same type of tire and the same pressure.
With regard to why wider tires are better, there are many factors but a big one (I think the biggest) is that in narrower tires, more of the tread pattern lifts of the ground due to sidewall deflection.
Old Jan 14, 2005 | 06:07 PM
  #122
dgussin1's Avatar
dgussin1 is infamous around these parts
Originally posted by cjv
In a month or so my turbo will be finished. It weights 3092 pounds. It will redline @ 10,000 rpm's. It has a few more ci's than a stock turbo, but not as many as the CGT. It should have a hp/weight ratio of about 2.6 to 1. The gearing will be almost identical to the CGT's in all gears. It does have a very considerable suspension mod and tires have a width that will more than match. The brakes come directly from a GT3 RS.
I'm sure given a little time we'll run into one that wants to play.
By the way, I am a fan of the CGT. It is a great car abeit a little different. I hope to own one sometime in the future.
how much did that cost? prolly more than my whole car and my mods!
Old Jan 14, 2005 | 06:27 PM
  #123
JarodL's Avatar
JarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of light
probably about 7 of your cars and mods.... seriously
Old Jan 14, 2005 | 06:31 PM
  #124
dgussin1's Avatar
isn't that just dumb. lol
If I was gonna spend money like that I would have bought a better platform to start with.
Old Jan 14, 2005 | 06:32 PM
  #125
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
why would you post something like that - seriously?
Old Jan 14, 2005 | 06:39 PM
  #126
dgussin1's Avatar
Old Jan 14, 2005 | 10:30 PM
  #127
cjv's Avatar
cjv
Moderator
Your assumption is this is my only car(s), my fastest car(s) ............... ................. I guess I'm not you.
Old Jan 14, 2005 | 10:34 PM
  #128
ben, lj's Avatar
Senior Member
yep, and that would be a very bad assumption
Old Jan 15, 2005 | 09:56 AM
  #129
PaulF's Avatar
PaulF is infamous around these parts
Tim,
I used the spare tire example as a know entity that you could use to envision the difference. I think that contact patch has to be related to tire width to some extent. If you mounted dramatically smaller tires of the same brand/tire pressures on your turbo, I am confident that your contact patch and braking performance would be diminished.
The difference in the GT's braking performance may also be attributed to the ABS threshold, which on the 996TT is very low from my experience at the track in my TT. Perhaps that Carrera GT has a more race oriented programming, which would account for the "staggering" braking performance at higher speeds that have been described by Ben (Ben, I would love a ride also someday)
Paul
Old Jan 15, 2005 | 10:06 AM
  #130
Paul, don't confuse static contact patch and dynamic patch and resulting performance. The static statement is correct, but when you get to performance, obvioulsy the wider tires generally perform better. The biggest reasons are sidewall lift and thermal breakdown of the smaller tire (it overheats much easier).
The CGT brakes are likely to be superior on the track and in exreme conditions. I have never disputed that. The performance probably is staggering under those condtitions, but not from a long g increase, but from maintaining the high long g number stop after stop after stop.
Is is quite possible that the CGT has different ABS algorithm with higher performance tires in mind, but I have no data to support this.
Old Jan 15, 2005 | 10:44 AM
  #131
996turbo's Avatar
996turbo is infamous around these parts
Man....this thread is all over the place. On that note, what do you guys think of this watch?
Old Jan 15, 2005 | 11:36 AM
  #132
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
Originally posted by 996turbo
Tyson....you wouldn't have the UPS tracking number on this package, would you?? If you get one...I want a ride buddy.
So that's where my car went. Oh, one of these days it will show up in my driveway.
Of course we'll go for a drive, Harry. Hope all is well, haven't seen you in a long time!
Old Jan 16, 2005 | 03:59 PM
  #133
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Craig
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
MDYUKI1016
Aug 24, 2015 04:40 PM
Glasig
Aug 23, 2015 03:35 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
