Carrera GT test drive
Originally posted by ColorChange
The point I am trying to make is that your car will not pull more decelerating g's than any decent sports car because the tires are it, and your tires aren't that different than the GT-3,
And as I said before, your statement of a staggering difference is just plain wrong.
And yes guys, if you take a car with the same brand of tires and the same tire pressure, 200 tires all around, compared to 345’s all around, the contract patch is the same. This isn’t obvious but it’s true. On the narrow tires, the contact patch is long but narrow (the tire gets a bigger flat spot). With the wide tires, the contact patch is very wide but very short, but the total area is the same.
Seriously Ben, don’t mess with me on technical issues, it’s my strong suit and not yours.
All in all, I still love your car.
Originally posted by Hamann7
Tim, I can assure you that the equation changes when you put on the Brembo GTR kit.
Arling had them on his old Turbo and the deceleration was significantly stronger than any sports car I've ever been in. They are INSANE!!!
Originally posted by dgussin1
A change in suspension can attribute to better braking even more than increasing rotor and caliper size.
OMG does it really matter what the cars do 0-60? This is one of the most idiotic arguments I've ever heard aside from Colorchange's rant on the Rennlist when he got laughed off that forum by drivers that actually know what they are doing. Give it a rest already....
Tyson,
Do you have to hijack every thread and pitch the GT2 to everybody? Yes, it is a great car but it is no CGT or GT3RS.....
Tyson,
Originally posted by collin996tt
I can smack an unbelted Kirby into the windshield of my Land Rover at a mere 40 mph and it'll put a staggering bump on his forehead. Anyone want me to prove it?
Please send me the video as soon as you smack his head to the windshield!
Originally posted by ben, lj
Well I tried to make that point, but Tim is claiming "This is marginal at best.". What are your technical explainations for your comment re: suspension improving braking?
PS, can I have a ride in your CGT? Please!
I have also seen recorded data that shows a brake upgrade providing similar, but not as good of gains on the same type of car. I believe the went from 116 to 109, but it was much more consistant on the track.
The biggest difference we felt was the car had WAY less nose dive which we attributed to the better braking.
I don't have any logged technical data, outside of me recording some stuff with some friends on his coil overed car before and after. We had data that said a 60-0 before was around 115-118 ft and after was around 106-109 ft. With nothing changed except for coil overs and a few other suspension mods. The biggest difference we felt was the car had WAY less nose dive which we attributed to the better braking.
PM me next time you're going to be down here and I'd be happy to go for a drive.
I like the brake theory of Tim's, but I just don't see it in the real world. Cars with larger tires and brakes, don't brake as well as the 996tt from 100mph. There was an article on this in Road&Track. And yes, I do not believe the TT had a weight advantage, most of the others as I recall were RWD.
Edit: I found this old report, but the bar graphs are poor.0-100-0
but he may want to know more about how scientific your measurement was.
I just took my car in to the OKC dealer today and was completely shocked to find an '05 CGT on the show room floor, absolutely beautiful! It sure does sit low. I would be afraid to drive it on a lot of the roads around here due to how low it sits. My friend the GM told me that they had a guy take a rock on the wind shield recently and it cost him 9K to replace it! Also, the battery apparently is somewhere up underneath the car with a warning in the manual not to even try to access it unless you're the dealer. The carbon fiber throughout the car and engine compartment is out of control, never seen anything like it. Boy, it's cool though.
Thanks,
Ted.
Thanks,
Ted.
Thanks,
Ted.
Thanks,
Ted.
