Remote Key does not lock / unlock doors after battery change
Old Dec 23, 2011 | 07:08 PM
Twinturbofan's Avatar
Twinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud of
$20 program at the dealer? My local dealer wanted $135!
Old Dec 24, 2011 | 10:50 AM
Slider's Avatar
The key fobs are VERY sensitive and fail often. The dealer told me that, if you change the battery, you only have about 5 seconds to make the switch once the battery is removed. These keys are actually programmed to self-destruct under certain conditions. For instance - if you accidentally press the unlock button when away from the car (like sitting on your keys) and you activate the unlock 255 times (about 20 seconds of sitting), the key will temporarily disable itself. It can be reset using the unlock - start the car method. But, if you activate 1024 times - the key fob is toast. It will still start the car, but God himself cannot reactivate the unlock feature.
Old Dec 24, 2011 | 02:42 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Turbotwin, I have a friend at a local Porsche tuner shop he helps me out quite a bit with prices. But the key on eBay is diffently the way to go. I did it for two different turbos over the years worked perfectly. Just make sure it has the bar code paper with it and that it was never programmed on another car or it's useless. (tried to reuse an old key off my original turbo with the original bar code and get it to work with the new one but no dice)
Old Dec 26, 2011 | 12:46 PM
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
Originally Posted by gearhead
Had mine die as well. I use it as a spare now. Go on eBay buy a key head that still has the barcode tag(very important) get it programed, problem solved. I tried everything too nothing worked for me either.
I bought my key head with uncut blade for $70 with the barcode on eBay. $20 programming at the dealer. I refused to pay that insane dealer replacement key price.
$20??? My Dealer wants $180 for programming!!! Can we have this done locally only or?..
Old Feb 5, 2015 | 08:57 AM
ianBall's Avatar
ianBall is infamous around these parts
Discovered this by accident, unlock the car door with the key, sit in the drivers seat wait for the alarm to go off, put the key in the ignition and turn on. My keys now work normally.
Old Feb 5, 2015 | 09:03 AM
Slider's Avatar
Why would the alarm go off if you unlock the car with the key? How long did you have to wait?
Old Feb 5, 2015 | 09:10 AM
ianBall's Avatar
On my cayman, after about six seconds the alarm goes off if you don't put the key in the ignition and you haven't turned the alarm off with the key fob button.
Old Feb 5, 2015 | 09:12 AM
Slider's Avatar
I have to try this...
Old Feb 5, 2015 | 12:36 PM
wross996TT's Avatar
This is the typical action to wake up the key fob as it will go to sleep after 5 days...
Old Feb 5, 2015 | 03:46 PM
Slider's Avatar
I gave it a shot - 10 minutes - no alarm. (An my IR sensors work - alarm will go if you lock the car and put your hand in the window)
Old Feb 5, 2015 | 04:04 PM
BLKMGK's Avatar
Leave the car and key fob sitting for about 4-5 days. When you try to open the car with the fob it will fail and you will have to use the key. If you open the door with the key and do not turn on the ignition fairly quickly the alarm will sound until you disable it. Happens to me OFTEN!
Old Feb 5, 2015 | 05:03 PM
Slider's Avatar
... Sorry, not possible... there is no way I could leave the car sitting for 5 days without driving it!
Old Feb 18, 2015 | 11:23 PM
Saadi996tt's Avatar
Saadi996tt is infamous around these parts
Hello Gents,
I have a similar problem...
Car only gets driven once a week so it's plugged into a battery tender. Tried to drive the car this morning and as usual the key fob didn't work so I proceeded to unlock like I do every week and guess what I can't open the door manually either. I tried both my keys and no luck turn it to the right or left and still can't get inside the car. I finally opened the frunk with the emergency cable, alarm went off and woke everyone up! I disconnected the battery and took another car to work. Has anyone experienced this issue and any possible fixes??
Thanks,
Saadi
Old Feb 18, 2015 | 11:33 PM
Slider's Avatar
You can't open the door manually? Why not? Does the key fit, but not turn? Does it turn but nothing happens?
Old Feb 18, 2015 | 11:35 PM
Saadi996tt's Avatar
Key turns but nothing is happening, I'm lifting up the handle and no go, door is still locked
