Rods Rods Rods......
Old Jan 18, 2005 | 11:20 PM
K24madness's Avatar
K24madness is infamous around these parts
Who wants to settle a score.
Since you 996 guys push your cars to the limit maybe someone can answer this.
I run my 993tt with K24's and race gas at 1.3 bar. Some people seem to think the rods won't hold out at those levels. If I understand it correctly the rods are the same as the 996 and I see X50 guys push it to those levels often.
Last time I checked on the dyno I got 460whp & 474 wtq at 1.1 bar. I believe I am well within safe limits. Any thoughts?
Old Jan 18, 2005 | 11:29 PM
FAT-911's Avatar
FAT-911 is infamous around these parts
993's & 996's have the same internals however the cooling system in the 996 has allowed the limits to be pushed somewhat more than the air cooled cars.
Old Jan 18, 2005 | 11:31 PM
sharkster's Avatar
Yah know I spoke to Garret about this and **** I've been pushing more boost than that for over 2 years and put 31k of miles on my car (as have many more) and I don't think they're as weak as people say.. Now shoot NOS or 2bar consistently and then ok... I think you're ok. The other guys will have more Stephen, Todd, Kevin, CJV but even though I need to do mine I haven't yet done it
Old Jan 18, 2005 | 11:46 PM
03-turbo911's Avatar
Senior Member
Like Fat-911 said, the difference is in that the 996 turbo engine is water cooled so the limits are higher on it. Good thing that you run race gas as well, I wouldn't put anything less when running high boost.
Old Jan 19, 2005 | 06:15 AM
cjv's Avatar
cjv
Moderator
Alot has already been said above. Cooling does indeed have alot to do with it. The rods in the 993tt motor would generally be good to 700 rwhp ....... however the longevity of the motor won't be very good as in race car longevity.
The 996tt will take a little more, however this is subject to how you use the motor. If you push it past the stock redline to 7100-7500 rpm's very often, the rods will suffer. A TIP is alot easier on the rods versus a 6speed. In addition, if you do alot of standing starts with a car that has it's traction connecting to the ground down pat, this also tends to stress the rods.
At 500 or so hp, you shouldn't have any problem other than a little reduced motor longevity as compared to stock motor longevity.
Old Jan 19, 2005 | 08:02 AM
K24madness's Avatar
Thanks for the input guys.
K24's and race gas on the 993 is pretty damn fun at 1.2-1.3 bar. I guess the only advantage on my 993 is the weight.
Old Jan 19, 2005 | 04:52 PM
Zippy's Avatar
I'm thinking of getting rods this spring. I'm also very interested in a LSD. I hope to see some of you guys finding out what LSD to use before I ship my car south to get the work done!
Mike
Old Jan 19, 2005 | 05:05 PM
Arm's Avatar
Arm
Arm is infamous around these parts
Re: new rods for a 996 Turbo, anyone want to throw out a ballpark total cost?
Old Jan 19, 2005 | 05:43 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Approximately $1,800 (+/-) for the rods and $5,500-7,000 labor. Some are cheaper and others more expensive.
Craig
Old Jan 19, 2005 | 09:07 PM
cjv's Avatar
cjv
Moderator
Craig
Pretty accurate.
Old Jan 19, 2005 | 09:20 PM
sharkster's Avatar
Originally posted by cjv
Pretty accurate.
Don't you mean pretty Akkurat Chad
Old Jan 19, 2005 | 09:32 PM
cjv's Avatar
cjv
Moderator
ahhhhhhhhhhh, well yes, pretty akkurat.
Old Jan 19, 2005 | 10:20 PM
sharkster's Avatar
Of course I'll be paying James in computer parts, SoCal girlies and Lotus parts...
Old Jan 20, 2005 | 06:36 PM
jayster's Avatar
jayster is infamous around these parts
rods or pretzels?
I have seen a 993TT, 3.8L @ 1.4 to 1.6 bar
boost live for a short while on a diet of PMS (porsche motorsports) connecting rods (something I wouldnt have done), then after a "normal" roadtest, came back with a "knock", it was dissassembled and reassembled twice (not by me!!) and still was knocking. In passing I commented to the tech, jokingly that "I thunk them thar rods were a tad crooked...and with a little salt might taste like pretzels" Anyway they installed Carillos, and I didnt say I told you so...
A set of Carillos should run about 1.8 to 2.0 g's, depending on your parts guy.
Stock rods or PMS rods are safely good for no more than 650 to 700 CHP ( crankshaft HP's) from my experience. Anyway thats my story and I'm sticking to it.
Peace Jayster
Old Jan 20, 2005 | 09:42 PM
K24madness's Avatar
Thanks for your input Jayster.
I am well south of 650 HP. I am trying to target 500WHP (600 crank). That should allow a safety margin.
Thunder915
Oct 1, 2019 07:34 PM
awesomebang
Jul 5, 2017 08:48 PM
Glasgo
Nov 30, 2015 02:37 PM
panas001
Sep 27, 2015 02:51 PM
ECS Tuning - VW
Sep 25, 2015 10:48 AM
