Errors from the exhaust ( w/o cats )
Old May 21, 2010 | 06:06 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Exclamation Errors from the exhaust ( w/o cats )
After I run hard the car I receive this errors :
-P0430
-P0420
should I be worried about this ?
It seems that the tuner can't bypass the cats... how do you guys run?
Thanks!
Old May 21, 2010 | 07:27 AM
landjet's Avatar
Did you also remove the O2 sensors?
Old May 21, 2010 | 07:41 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Those are very easy to correct =)
Old May 21, 2010 | 07:53 AM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
Strange, I removed the cats on my system and get different codes.
p0139 and p0159
I wonder why we have the same modification and different code both attributed to the catalytic converter / o2 sensors
Old May 21, 2010 | 08:13 AM
alex55's Avatar
the sensors are mounted in the exhaust.
@Nola911: maybe is a difference between US and EU
@Tony: this is the second file that they send me but it seems that they didn't do it right.
Old May 21, 2010 | 08:19 AM
Sales@Champion's Avatar
Sales@Champion is a splendid one to beholdSales@Champion is a splendid one to beholdSales@Champion is a splendid one to beholdSales@Champion is a splendid one to beholdSales@Champion is a splendid one to beholdSales@Champion is a splendid one to beholdSales@Champion is a splendid one to behold
You can either correct the cat inefficiency codes with programming ( omitting the second 02 sensor ) or with 02 simulators. If you have any questions, we will be happy to help.
Old May 26, 2010 | 04:08 AM
alex55's Avatar
Does anybody know if there is any difference between the european ecu and US one?
Is here someone from EU that runs w/o cats?
It seems that they cannot "bypass" the O2 sensors from the ecu...
Any help please!?
Old May 26, 2010 | 07:20 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
i hope that's not the case, my car's euro spec as well but haven't installed the catless yet. but have double checked with vendor and the flash I'm using is supposed to work w/o cats.
Old May 26, 2010 | 09:35 AM
NOLA911's Avatar
I hope a vendor or someone else with some knowledge of the codes can give us a little insight on the 4 different o2 related codes
I would think Euro and US spec codes should be similar or the same.
Old May 26, 2010 | 09:39 AM
Tony@epl's Avatar
The the cats are coded out properly... it takes care of all 4 codes. (there are actually as many as 6 that can pop up).
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
jyupitt1
Sep 23, 2015 06:26 AM
bmwtmx
Aug 26, 2015 07:26 AM
